POV-Ray : Newsgroups : povray.newusers : loss of color coding in editor Server Time
26 Mar 2026 07:48:31 EDT (-0400)
  loss of color coding in editor (Message 1 to 4 of 4)
Subject: loss of color coding in editor
Date: 20 Sep 2011 11:50:01
Message: <web.4e78b50679ca9e9f3fb4713c0@news.povray.org>
I'm using POV-Ray for Windows
Version 3.6.2.msvc9-sse2.win32
with the Windows 7 Home Premium operating system.
I've lost the color coding in the editor. I can select "Black On White" or
"White And Black" from item "Color Scheme" on the Editor menu. When clicking on
"Custom" I get the "Window Properties" window. On the "Colors"/Font" tab I see
that colors are assigned to various items, for example, a dark green to
comments, magenta to keywords, red to operators, etc. Yet when I select "Custom"
I don't get the colors in the editor. Am I doing something wrong or is this a
known bug?
I was getting the colors but for some reasons they simply disappeared!
Subject: Re: loss of color coding in editor
Date: 21 Sep 2011 01:47:40
Message: <4e797a7c$1@news.povray.org>
Am 20.09.2011 17:45, schrieb Bolek:
> known bug?
Try the following: Open the "Window Properties" (shortest way is to
press Alt+Enter), then...
- on the "Language/Tabs" tab, verify that "Language" is set to "POV-Ray";
- on the "Misc" tab, verify that "Color syntax highlighting" is enabled.
(I'm using the POV-Ray 3.7 GUI as a reference here, but AFAIK nothing
has been changed from 3.6 regarding syntax highlighting.)
Date: 21 Sep 2011 09:30:00
Message: <web.4e79e6a76d7257083fb4713c0@news.povray.org>
> > I've lost the color coding in the editor. ...>
> > Try the following: Open the "Window Properties"  - on the "Language/Tabs"
tab, verify that "Language" is set to "POV-Ray...
Thank you. That was my problem, it was not set to "POV-Ray."
Date: 21 Sep 2011 13:23:30
Message: <4e7a1d92@news.povray.org>
Am 21.09.2011 15:29, schrieb Bolek:
FYI, POV-Ray stores the "Language" setting on a per-file basis (for the
most recently opened files), so if you had this problem with more than
one file you will need to re-set the setting for each one individually.
