POV-Ray : Newsgroups : povray.newusers : Rotating triangle around middle point Server Time
12 Aug 2025 18:20:34 EDT (-0400)
  Rotating triangle around middle point (Message 1 to 6 of 6)
Subject: Rotating triangle around middle point
Date: 11 Sep 2011 17:55:00
Message: <web.4e6d2d8138a9622beee66afe0@news.povray.org>
Hi, once again I've stumbled upon a problem. I have two triangles which are not
parallel to any axis. I want it so that one of the triangles rotates around in
place until it is pointing the opposite way of the other one, forming a
hexagram.
If I use scale -1, the triangle does go to it's opposite, but as soon as I put
in a clock the "rotating" triangle shrinks and continues to grow in size
pointing the opposite way all the time.
example code for rotating triangle:
#declare a = <1,1,0>;
#declare b = <1,0,-1>;
#declare c = <0,1,-1>;
//moving
triangle{ a, b, c
pigment{rgbf <1,0,0,.5>}
translate -a/3 translate -b/3 translate -c/3
scale -1 * clock
translate a/3 translate b/3 translate c/3
//stationary
triangle{ a, b, c
pigment{rgbf <1,1,0,.5>}
any help would be appreciated, thanks.
Subject: Re: Rotating triangle around middle point
Date: 11 Sep 2011 18:23:06
Message: <4e6d34ca@news.povray.org>
> hexagram.
> #declare a =<1,1,0>;
> #declare b =<1,0,-1>;
> #declare c =<0,1,-1>;
> //moving
> triangle{ a, b, c
> pigment{rgbf<1,0,0,.5>}
> scale -1 * clock
> //stationary
> triangle{ a, b, c
> pigment{rgbf<1,1,0,.5>}
You correctly move your triangle around the origin, transform it, then
translate it back in it's desired location. Good.
Your "scale -1*clock" (same as scale<-1,-1,-1>*clock) is an isotrope
scaling. What you seems to want is a rotation of your triangle going
from 0 to 180 degree over the course of your animation.
It may also be that you want your triangle to shrink down to almost
nothing, then grow back as a reversed image of it's original shape.
First case, use rotate [axis]*clock*180
Second case, you need to adjust your scaling range. Sample:
scale 1-clock*2
This gives an effective range going from <1,1,1> to <-1,-1,-1>.
This will make your object start at it's full size, shring down, then
expand back to it's original size but with it's dimentions inverted.
In this case, you MUST ensure that clock NEVER reatch exactly 0.5. This
will cause a scaling by zero whitch is undefined and will default to
scale 1 with a warning been isued.
Date: 11 Sep 2011 19:18:46
Message: <4e6d41d6$1@news.povray.org>
> hexagram.
I read your question differently from Alain. It all depends how you want
your triangle to rotate. If you want it to rotate around its centre of
gravity. then you construct it so that the centre of gravity (or the
centre of rotation) is at the origin. Rotate it, with the clock
variable, then move it to the required position. You may need to rotate
it using the three axis and the sin and cos functions.
Regards
Date: 11 Sep 2011 20:55:00
Message: <web.4e6d5808dbede6f8eee66afe0@news.povray.org>
> Your "scale -1*clock" (same as scale<-1,-1,-1>*clock) is an isotope
> scale 1-clock*2
> This will make your object start at it's full size, shrink down, then
> expand back to it's original size but with it's dimensions inverted.
> In this case, you MUST ensure that clock NEVER reach exactly 0.5. This
> will cause a scaling by zero which is undefined and will default to
> scale 1 with a warning been issued.
> Alain
Ok, I'll use
, but I don't know how to find the axis.
from the three points I made a 4th one which was the center of the 3, which the
triangle is supposed to rotate on
#declare d = <2/3,2/3,-2/3>;
but I don't know how to rotate it around and keep the 2 triangles coplanar.
OK I'll stop "lying". I actually want to make an animation where an icosahedron
has triangles which grow to a specified size, and rotate (on axis) 180 degrees
during the growth.
here is an example
#declare B  = <0,1,-1.618>;
#declare E  = <1,1.618,0>;
#declare J  = <1.618,0,-1>;
union{
triangle{ B, E, J pigment{ rgbf<1,0,0,0>}    //colour and points
translate -B/3 translate -E/3 translate -J/3 //translate to origin
scale (14 + 6 * sqrt(5)) / 4 * clock         //specified resize
rotate <0,0,0>                               //the part where it rotates 180 on
the axis, need help on this
translate B/3 translate E/3 translate J/3    //translate back
finish{ambient 0.5}                          //brighter :P
so if you can please clarify the axis part, thanks.
Date: 11 Sep 2011 23:55:00
Message: <web.4e6d81a5dbede6f8776f1f120@news.povray.org>
> Ok, I'll use
> during the growth.
> here is an example
> union{
I think you are just looking for the normal of the triangle right?  If so, you
can just use a cross product..
  Axis_Rotate_Trans(vcross(E-B, J-B), 180)
There may be a more elegant way but I think that will work.
Date: 12 Sep 2011 17:43:51
Message: <4e6e7d17@news.povray.org>
>> scale 1-clock*2
>> This gives an effective range going from<1,1,1>  to<-1,-1,-1>.
>> Alain
> Ok, I'll use
> #declare d =<2/3,2/3,-2/3>;
> during the growth.
> here is an example
> #declare B  =<0,1,-1.618>;
> #declare E  =<1,1.618,0>;
> #declare J  =<1.618,0,-1>;
> union{
> rotate<0,0,0>                                //the part where it rotates 180 on
For that, it may be beter to originaly create all your triangles along
rotation around a single axis (Z, Y or X), then rotate and translate
them to the desired final orientations and locations.
It may look more complicated, but, in the end can be much simpler to
implement.
OR
You can go along with the proposition of Solar Mike and use:
Axis_Rotate_Trans(vcross(E-B, J-B), 180*clock)
You need to add:
#include "transforms.inc"
early in your scene to use that.
Other notes:
I don't recomend the use of finish{ambient 0.5} to make something
brighter. This tend to flatten your shading and make you loose the 3D
quality.
Increase the light's intensity instead, it's intensity is not limited to
rgb<1,1,1>.
You can use another light, possibly coloured, to make shadowed parts
brighter.
If you don't use transparency, use rgb<1,0,0> instead of rgbf<1,0,0,0>.
Here, also, the colour range is not limited to 0~1 range. Be carefull
that you don't over saturate your colours and cause some clipping.
If your union only contains a single component, use object instead.
If all the components of an union share the same texture, apply that
texture to the union as a whole and only give a texture to a component
that have a different texture.
