POV-Ray : Newsgroups : povray.newusers : Scientific Visualization of 2-D and 3-D Arrays Server Time
7 Apr 2026 11:36:55 EDT (-0400)
  Scientific Visualization of 2-D and 3-D Arrays (Message 1 to 3 of 3)
Subject: Scientific Visualization of 2-D and 3-D Arrays
Date: 25 Aug 2011 12:30:01
Message: <web.4e5677aa993004a59d114f5e0@news.povray.org>
Dear all,
I'm a new user of POVRAY.
Now I'm gonna use POVRAY for visualizing ground motion on the surface of the
Earth. The computation results give us a 3-D volume of ground motion amplitudes,
and I want to show these amplitudes on topography and subsurface. I found the
figures on the internet and these are exactly what I want:
For 2-D array:
http://www.eri.u-tokyo.ac.jp/furumura/tsunami/Zisin_snap.jpg
For 3-D volume:
http://www.eri.u-tokyo.ac.jp/furumura/scat/3Dsnap.jpg
Now I can draw topography and sea floor, but I have no idea for visualizing the
seismic wave. My question is, which functions should I use for this purpose,
including visualizing 2-D and 3-D datasets?
Thank you.
Best Regards,
M.-C. Hsieh
Subject: Re: Scientific Visualization of 2-D and 3-D Arrays
Date: 25 Aug 2011 12:53:01
Message: <4e567dec@news.povray.org>
> For 2-D array:
> For 3-D volume:
  If you have a heightmap, then the easiest way of rendering it is using
the heightfield primitive (which can be instantiated directly with a B/W
image file where each shade of gray represents an altitude). An unmodified
heightfield will be fitted inside a 1x1x1 cube, so you'll have to use the
'scale' transformation to get it to the proper size on each direction.
  Rendering a 3D point could is a much harder problem and does not have
any trivial, unambiguous solution. One possible solution is to create a
DF3 file, which is basically a 3D density file (an NxNxN cube of density
values) which you can then use to instantiate a cube-shaped media effect.
However, getting it to render properly, while not impossible, can be an
arduous task of fine-tuning parameters and color maps.
Date: 25 Aug 2011 14:15:01
Message: <web.4e5690e4435fca3f9d114f5e0@news.povray.org>
> > For 2-D array:
> > For 3-D volume:
Thank you, Warp. These advises are quite useful to me.
For visualizing a 2-D array, I believe the easiest way is by using heightmap.
On the other hand, I also found interesting movies for plotting the seismic
wave:
http://www.youtube.com/watch?v=98R2d66dlgI&feature=related
http://www.youtube.com/watch?v=Bh2Aj-MLpIo
I guess the movie is not made by heightfield.
How can I do that? By using mesh-related functions?
Thanks again.
M.-C.
