POV-Ray : Newsgroups : povray.newusers : Parse Warning: Points in polygon are not co-planar. Ignoring polygons. Server Time
7 Apr 2026 11:37:00 EDT (-0400)
  Parse Warning: Points in polygon are not co-planar. Ignoring polygons. (Message 1 to 5 of 5)
Subject: Parse Warning: Points in polygon are not co-planar. Ignoring polygons.
Date: 9 Jul 2011 07:15:00
Message: <web.4e1837fb53f9b006e70ca0910@news.povray.org>
While rending a generated script, I get:
File: test.pov  Line: 16077
The line is:
polygon { 5 <110, 25, 2>, <111, 25, 2>, <111, 26, 3>, <110, 26, 2>, <110, 25, 2>
texture{pigment{rgb <0, 0.461435456673892, 0.443295311143663>}} }
What is wrong and how can I fix it?
Subject: Re: Parse Warning: Points in polygon are not co-planar. Ignoring polygons.
Date: 9 Jul 2011 09:34:05
Message: <4e1858cd@news.povray.org>
news:web.4e1837fb53f9b006e70ca0910@news.povray.org...
> Hi,
> The line is:
> 25, 2>
google is your friend : http://www.povray.org/documentation/view/3.6.0/294/
Date: 9 Jul 2011 12:15:00
Message: <web.4e187e105bfbb31de70ca0910@news.povray.org>
> > The line is:
> > 25, 2>
Yes, ok, but how do I fix this?
Should I split it (it is a square) in 2 triangles? Or do the same rules apply?
Date: 9 Jul 2011 13:06:54
Message: <4e188aae$1@news.povray.org>
>>> The line is:
>>> polygon { 5<110, 25, 2>,<111, 25, 2>,<111, 26, 3>,<110, 26, 2>,<110,
>>> 25, 2>
>>> texture{pigment{rgb<0, 0.461435456673892, 0.443295311143663>}} }
Your problem is that the polygon is not a square. It would only be a square
if it was coplanar. Coplanar means the points are in one plane (which does
*not* mean the plane has to be axis aligned!), as otherwise the polygon's
plane is not fully defined - imagine a sheet of paper that you hold on to
diagonal corners. Depending on which corner of the two possible diagonal
corners you pick, it will be a different shape. The same problem exists with
a polygon with more than three corners. You have to pick the corner
coordinates properly for it to be in one plane.
See:
<http://en.wikipedia.org/wiki/Coplanarity>
You can search for the error message:
<http://www.google.com/search?q=Points+in+polygon+are+not+co-planar.+Ignoring+polygons.>
This will lead you to:
<http://news.povray.org/povray.newusers/thread/%3C419e827f$1@news.povray.org%3E/>
Date: 9 Jul 2011 15:07:00
Message: <4e18a6d4$1@news.povray.org>
> Hi,
> The line is:
> polygon { 5<110, 25, 2>,<111, 25, 2>,<111, 26, 3>,<110, 26, 2>,<110, 25, 2>
Look at the third point Z coordinate... It's 3, all others are 2.
