POV-Ray : Newsgroups : povray.newusers : Strange checker behavior, overlapping perspective lines Server Time
12 Aug 2025 18:40:39 EDT (-0400)
  Strange checker behavior, overlapping perspective lines (Message 1 to 4 of 4)
Subject: Strange checker behavior, overlapping perspective lines
Date: 31 May 2011 13:35:01
Message: <web.4de526458194c21a97074f4f0@news.povray.org>
   I've been trying to add a checkered plane to an image. The plane itself can
be generated with a POV-Ray file comprising:
   perspective
   location <15, -12, 72>
   look_at <-1,3,35>
   sky <1,-1,0>
light_source {
   <50, -20, 35>, color rgb<1.000,1.000,1.000>
   parallel
   point_at <0,0,20>
plane { <1,-1,-0.1>, -30
   pigment { checker rgb<0.8, 0.8, 1.0>, rgb<1.0, 1.0, 1.0> scale 20}
With POV-Ray 3.6.2 under Windows XP (Mac Parallels VM), I see overlapping lines
of checkers that look like they're going to different perspective points (sorry
I can't attach a file here, please let me know an e-mail address and I'll be
happy to send along a PNG of what I see). I was expecting a simple checkered
plane rather than two overlapping ones. What am I doing wrong here?
Thanks for any help!
Subject: Re: Strange checker behavior, overlapping perspective lines
Date: 31 May 2011 14:30:00
Message: <web.4de532f17f585cfa97074f4f0@news.povray.org>
"Chris" <nomail@nomail> wrote:
> Hi,
> camera {
>    perspective
>    look_at <-1,3,35>
>    sky <1,-1,0>
> light_source {
>    parallel
>    point_at <0,0,20>
It seems to have something to do with specifying the plane using negative
values...
Date: 31 May 2011 17:56:04
Message: <4de563f4@news.povray.org>
> Hi,
> camera {
>     perspective
>     location<15, -12, 72>
>     look_at<-1,3,35>
>     sky<1,-1,0>
> light_source {
>     parallel
>     point_at<0,0,20>
> plane {<1,-1,-0.1>, -30
This is the reason for what you see: plane {<1,-1,-0.1>
The checker pattern is composed of alterning unit cube areas or two
pigments or patterns, alligned to the base axis.
AND
Your plane is tilted relative to the checker pattern.
It would be beter to set your plane as follow:
plane{-1*y, -30
  rotate<-45,0,1>
Adjust the rotation as needed.
You could also rotate the checker pattern so that it's orientation
matches that of your plane.
Another possibility, is to shift the pattern and scale it by some large
value in ine direction:
pigment { checker rgb<0.8, 0.8, 1.0>, rgb<1.0, 1.0, 1.0>translate -0.5*y
scale<20, 99999, 20>}
And, no, the use of negative values have nothing to do with your result.
Date: 31 May 2011 18:42:49
Message: <4de56ee9$1@news.povray.org>
Am 31.05.2011 19:32, schrieb Chris:
> (sorry I can't attach a file here, please let me know an e-mail address and
> I'll be happy to send along a PNG of what I see).
A common practice in such cases is to describe the problem here (or in
whatever newsgroup it fits best), and post the image to
povray.binary.images using the same subject line (you should be able to
attach files there).
