POV-Ray : Newsgroups : povray.newusers : Photons, saturation and using the photon map outside povray Server Time
26 Mar 2026 09:43:18 EDT (-0400)
  Photons, saturation and using the photon map outside povray (Message 1 to 3 of 3)
Subject: Photons, saturation and using the photon map outside povray
Date: 27 May 2011 13:10:01
Message: <web.4ddfda916d6777ce76ac49870@news.povray.org>
Dear all,
I'm using povray to model the focusing and retro-reflection of glass
microspheres, so a pretty simple set up really. The problem that I am having is
that the areas where the photon density is high and the situations where the
spheres are re-imaging the light source at the camera (i.e the plane is near the
focal point of the shperical lens and the camera and light source are on the
same axis) the image saturates completely.
Two questions. 1./ Can the levels of the image be scaled to use the high
brightness areas from the photon regions?
2./ Are there any programs to extract the data from the photon map for analysis
elsewhere?
Below is a simple scene to demonstrate the saturation
// ----------------- Includes and declarations -------------------------------
#include "textures.inc"
#declare AMBILIGHT = 0.1;
// ---------------- Global Settings -----------------------------------
global_settings {
                photons {
                        //count 2000000
                        //radius 10
                        spacing 0.01
                        autostop off
                        jitter 0.4
                        save_file "photon map.ph"
                        //load_file "photon map.ph"
                        adc_bailout 0.0000153
                        max_trace_level 10
// ---------------- Cameras --------------------------------------------
#declare cam1 = camera { orthographic
                         location <5, 10, 0 >   //camera should be placed above
the origin 5 units//
                         look_at  <5, 0, 0>
                         sky y   //looking back at the origin
                         //right <1.33, 0, 0>
                         //angle 10
camera {cam1}
// ------------------   Light Sources ----------------------------//
#declare light1 = light_source { <10, 3, 0>
        colour White*1   //light source colour and power
        //area_light  <0,1,0>, <0,0,1>, 3, 3     //area light
        cylinder
        radius 2
        falloff 2.2
        parallel    // All rays are launched parallel
        point_at <5, 0, 0>    // position vector that light rays are launched at
        photons{
        reflection on
        refraction on
#declare light2 = light_source { <4, 5, 0>
        colour <0.4,0.6,0.8>*0.1   //light source colour and power
        cylinder
        radius 5
        falloff 5.1
        point_at <4, 0, 0>    // position vector that light rays are launched at
        photons{
        reflection on
        refraction on
light_source {light1}
light_source {light2}
// ------------------   Objects -------------------------//
plane { y, 0
 texture { pigment { rgb <0.5, 0.5, 0.7> } }
 photons{
         reflection on
         collect on
 finish { diffuse 1.0
         specular 0.0
         ambient 0.0
  #declare Sradius = 0.5;
  sphere {<0,Sradius,0>, Sradius
          texture { pigment { rgbt 1 }
          interior {
                ior 1.8
          finish{ ambient AMBILIGHT
                diffuse 0
                reflection {0, 1.0
                fresnel on}
                conserve_energy
          photons { target 1.0
                refraction on
                reflection on
                collect off
          translate <4.5,0,0>
  #declare Sradius2 = 1;
  sphere {<0,Sradius2,0>, Sradius2
          interior {
                ior 1.5
                diffuse 0
                reflection {0, 1.0
                fresnel on}
                conserve_energy
                refraction on
                reflection on
                collect off
          translate <5.5,0.0,2>
Subject: Re: Photons, saturation and using the photon map outside povray
Date: 27 May 2011 20:07:26
Message: <4de03cbe@news.povray.org>
> Dear all,
> elsewhere?
The saturation comes from the clipping when the intensity becomes to
great to be represented in the used image format.
If you use version 3.6, it's possible to add a darkening filter in front
of the camera. A simple thin box with a gray filtering pigment. Be sure
to set it with photons{collect off} as you don't want any photon showing
on it.
You can also reduce the strenght of the light_source.
If you use version 3.7, you can output the image in a high dynamic range
format.
For the point 2, I don't know of any.
Date: 30 May 2011 06:37:46
Message: <4de3737a$1@news.povray.org>
On 28/05/2011 01:07, Alain wrote:
>> Dear all,
>> having is
>> where the
>> is near the
>> on the
>> analysis
>> elsewhere?
> on it.
> format.
> Alain
Thanks Alain, I'll get version 3.7 and try the hdr options
