> Am 09.04.2011 10:48, schrieb Stephen:
>> I can't say that I agree with either you or StephenS. Machine written
>> code is never elegant, from the little I've seen. So what difference
>> does an extra line or two make?
> Speed and memory consumption.
> Using a union for a single object will add unnecessary overhead, roughly
> duplicating the memory required per letter; it also /will/ impact render
> time, if ever so slightly.
Even if I had NO idea that it would greatly increase the memory use, it
comfirm my gut feeling of it been a prety BAD practice.
If you uselessly use an union for a mesh, especialy if it's a big one,
you're going to burn your memory...
Just DON'T use a construct if it's not needed.
