POV-Ray : Newsgroups : povray.newusers : Invisible plane to shade objects Server Time
7 Jul 2024 09:29:39 EDT (-0400)
  Invisible plane to shade objects (Message 11 to 11 of 11)
Subject: Re: Invisible plane to shade objects
Date: 10 May 2011 08:45:52
Message: <4dc93380$1@news.povray.org>
Am 06.04.2011 21:23, schrieb gregtom6:
> The lightning object is a spaceship, and it has got a lot of point lights. If I
> reduce the fade distance and/or fade power, that won't light the ship.
> The lights are enough strong on the ship, but too strong, if an object is too
> close to the ship.
Note that fade_distance is a crucial setting for realistic light
sources: This value should be in order of magnitude of the light
source's radius (e.g. in a scene with a scale of 1 m per POV-Ray unit,
0.025 would be a good value to simulate frosted light bulbs). As this
will also affect apparent light brightness, you'll have to adjust the
light source's brightness accordingly.
For realistic results, and presuming that you use assumed_gamma 1.0,
fade_power of light sources should always be 2.0. (If you prefer
assumed_gamma 2.2 for artistic reasons, a fade_power of 2.0/2.2 ~= 0.91
will probably look more convincing.)
