POV-Ray : Newsgroups : povray.newusers : Newbie question about functions Server Time
26 Mar 2026 09:44:37 EDT (-0400)
  Newbie question about functions (Message 1 to 9 of 9)
Subject: Newbie question about functions
Date: 20 Dec 2010 01:55:01
Message: <web.4d0efc974d34203e5656816c0@news.povray.org>
Why does this not work? It complains that I need to initialize X and Y before I
call them in the macro Fracp, but since I am passing them as parameters to the
function Gridd this would obviously be inappropriate. I have also tried changing
the macro into another function, but that doesn't work either.
#declare thick=0.05;
#macro Fracp(A)
 A-floor(A)
#declare Gridd = function( X, Y ) {
 #if ( Fracp(X)<thick | Fracp(X)>(1-thick) | Fracp(Y)<thick | Fracp(Y)>(1-thick)
   1
 #else
   0
Cheers,
H.
Subject: Re: Newbie question about functions
Date: 20 Dec 2010 05:06:46
Message: <4d0f2ab6$1@news.povray.org>
Am 20.12.2010 07:49, schrieb TheBigH:
> #macro Fracp(A)
>   A-floor(A)
> #end
>     1
>   #else
>     0
> #end
Note that "#" statements are always evaluated at parsing time, even when
used in a function. Therefore, "#if" statements cannot be used to
perform tests inside functions at run-time.
You will need to use the "select" function to have the condition
evaluated each time the function is called.
Date: 20 Dec 2010 07:25:00
Message: <web.4d0f4a45234b9e105656816c0@news.povray.org>
> > #macro Fracp(A)
> >   A-floor(A)
> > #end
> >     1
> >   #else
> >     0
> > #end
I see, thank for the heads up. I'm beginning to see that many things that are
straightforward and logical in other programming languages require awkward
contortions in POV-ray. Of course I could just do something like
#declare Gridd = function(X,Y) {
  (( X-floor(X)<thick )|(X-floor(X)>(1-thick))|( Y-floor(Y)<thick
)|(Y-floor(Y)>(1-thick)))
because the function I want only takes the values zero and one, but if I ever
want other values, or more than two different values, I need proper selection of
cases. And I would definitely have preferred a nice orderly succession of #ifs
to the horror of nested selects. Oh well.
Date: 20 Dec 2010 08:00:00
Message: <web.4d0f52a6234b9e10e619b42c0@news.povray.org>
The real question you should ask yourself is why you need a function at all and
if another macro won't suffice. The primary use of functions is for objects that
require runtime evaluation, i.e. isosurfaces, and a binary selection is not the
best solution. Another user for functions is in user-defined patterns, where
your problem mightbbe much better solved using a map, i.e. a color_map.
Thorsten
Date: 20 Dec 2010 11:05:44
Message: <4d0f7ed8$1@news.povray.org>
And a couple of additional trivial thoughts...
(1) Expressions of the type "x * (x > someDangNumber)" can be used in
functions--might something like this be useful?
(2) I notice that "X" and "Y" are capitalized--might this be a problem?
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 20 Dec 2010 11:30:43
Message: <4d0f84b3@news.povray.org>
  You can name function parameters as you like.
Date: 20 Dec 2010 14:20:00
Message: <web.4d0fab97234b9e1047ba06bb0@news.povray.org>
Are you sure ?
I do not have access to POV-Ray right now to check, but IIRC one (or more) is
problematic to use; like "t".
Tor Olav
http://subcube.com
Date: 20 Dec 2010 14:28:31
Message: <4d0fae5e@news.povray.org>
> Are you sure ?
  Ok, 't' is special for some reason. But eg. 'T' is fine.
Date: 20 Dec 2010 16:19:07
Message: <4d0fc84b$1@news.povray.org>
Just wondered if perhaps he was using the function in a context where x
and y might be expected (as in an isosurface, for example), as opposed
to explicitly passing two parameters.
--Sherry Shaw
