POV-Ray : Newsgroups : povray.newusers : Getting coordinates as text from a complex object. Server Time
18 Nov 2025 06:07:19 EST (-0500)
  Getting coordinates as text from a complex object. (Message 1 to 3 of 3)
Subject: Getting coordinates as text from a complex object.
Date: 14 Dec 2010 10:20:01
Message: <web.4d078adbec65b567dd7bdacd0@news.povray.org>
Hi I wonder if there is a way to get the coordinates as text from a complex
object.
Something that would look like #debug printobj(intersection(P1,P2,P3)).
Regards Spade.
Subject: Re: Getting coordinates as text from a complex object.
Date: 14 Dec 2010 10:26:21
Message: <4d078c9d$1@news.povray.org>
Am 14.12.2010 16:18, schrieb Spade:
> object.
> Regards Spade.
You can use
     #declare MyObj = intersection { P1 P2 P3 }
     #declare V1 = min_extent(MyObj);
     #declare V2 = max_extent(MyObj);
     #declare Center = (V1+V2)/2;
and then use the vstr() function to convert those vectors to string;
that would give you the dimensions and center of the object's /bounding
box/. Note however that this is not necessarily the smallest box in
which the object would fit.
Date: 15 Dec 2010 13:50:00
Message: <web.4d090d6321ca434f2baf18090@news.povray.org>
thank you for the help. Got it working
