![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am trying to generate the html files in the portfolio directory.
I get the error below in a lot of the files.
Parse Error, Negative Subscript
light_source {<-500,300,-500> rgb 1}
light_source {<500,500,500> rgb 0.7 shadowless}
union {
plane {y, 0}
sphere{
0,1
scale <0.6,0.3,0.6>
translate<0.55,0,0.5>
pigment{pigmentArr[frame_number-1]} /*** error here ***/
Another example is in c_colors.pov
light_group {
light_source {<-50,500,-200> rgb 1}
union {
plane {y, 0 no_shadow}
difference {
sphere{0,1}
box{<-1,0.9,-1>,<1,1.1,1>}
translate <0.7,0,0>
pigment{colorArr[frame_number-1]} /*** error here ***/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Jimmy" <nomail@nomail> wrote:
> Hi,
> union {
> plane {y, 0}
> sphere{
> 0,1
> scale <0.6,0.3,0.6>
> light_group {
> union {
> difference {
> sphere{0,1}
> translate <0.7,0,0>
frame_number is an internal variable, looks like it is relative to animations.
Are animations turned on when you render? (check your messages from the
rendering process)
Regards
Bidski
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 12/12/2010 09:25, Jimmy wrote:
> Hi,
Greetings,
which version ?
You must be aware that the portfolio must be rendered by the ini files,
not the pov files directly (unix version get a readme.txt , I do not
know if windows & mac get it also)
No problem to render portfolio of 3.7beta 40 on linux.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Hi,
> Greetings,
> which version ?
The readme is on my windows installtion (version 3.6). It also says at the top
of c_colors.pov
// Desc: Render via colors.ini,
// generates html files and images for all the
// colors in colors.inc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hi,
> union {
> plane {y, 0}
> sphere{
> 0,1
> scale<0.6,0.3,0.6>
> light_group {
> union {
> difference {
> sphere{0,1}
> translate<0.7,0,0>
Those must be used as an animation from the corresponding *.ini files.
Outside an animation, the internal variable frame_number is valued as zero.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
