POV-Ray : Newsgroups : povray.newusers : Creating a rotating gem Server Time
8 Jul 2024 05:10:43 EDT (-0400)
  Creating a rotating gem (Message 14 to 23 of 23)
Subject: Re: Creating a rotating gem
Date: 11 Dec 2010 01:45:01
Message: <web.4d031dd61e34407486c9e330@news.povray.org>
Or perhals this one? Although the bottom point of this one appears to be
shrowded in darkess .... hmmmm.
http://i288.photobucket.com/albums/ll167/Bidskii/stone6.jpg
Regards
Bidski
Date: 11 Dec 2010 15:18:25
Message: <4d03dc91@news.povray.org>
Am 11.12.2010 07:44, schrieb Bidski:
But you're definitely getting somewhere!
Date: 11 Dec 2010 19:15:00
Message: <web.4d0413861e34407486c9e330@news.povray.org>
Final product ..... 4 hours of rendering 120 frames with anti-aliasing. Im
surprised windows didnt die from the effort.
Regards
Bidski
http://i288.photobucket.com/albums/ll167/Bidskii/stone2-1.gif
Date: 11 Dec 2010 19:18:42
Message: <4d0414e2$1@news.povray.org>
You can apply the material to the whole thing instead of to each triangle.
> Here is the texture and material that I am using for all of the triangles and
> the mesh (material for mesh, texture for triangles).
> #declare Diamond_Tex = texture
>    pigment { rgbf<1, 1, 1, 1>  }
OK
>    finish
>      ambient 0
>      diffuse 0
>      brilliance 0.5
>      specular 0.9
>      roughness 0.05
I'd use a much smaller roughness value.
>      reflection
>        colour rgb<1, 1, 1>
>        0.1
>        fresnel on
This reflection is maximum at a perpendicular angle and minimum at a
grazing angle. You don't need the colour keyword here. "on" is not
needed after fresnel.
Proposed change:
reflection{0.1 1 fresnel}
Low perpendicular to strong grazing reflection obeying the fresnel model.
>      conserve_energy
OK
> #declare Diamond_Mat = material
>    texture { Diamond_Tex }
>    interior
>      ior 2.417
OK
>      caustics 1
Should not use, it can give unnatural results.
>      dispersion Diamond_Dispersion     // Defined in consts.inc
>      dispersion_samples 7
>      fade_power 2                      // Used because POV-Ray complained about
> me using refraction in the finish, said I should use fade_power and
> fade_distance instead.
>      fade_distance 1
>      fade_colour colour White
For the interior fade_power, a value of 2 is NOT correct. Use 1 (linear
fading) or 1001 (exponential fading).
Fade_colour White is mostly a do nothing.
In your case, you can remove all fade_ things.
refraction in the finish is a left over from old versions. It's not
needed as refraction appens automaticaly whenever you have an ior
different than 1.
Also, total internal reflection appens automaticaly.
> I added a sphere of radius 5 centered at the origin as an evironment (just added
> it) to no effect, I still get the same results as I did. I coloured it white. If
> I use rgb<1, 1, 1>  with a radius of 10 everything vomes up grey, with a radius
> of 5 the whole screen is a complete white-wash, using rgbf/t<1, 1, 1, 1>  gives
> me the same results as Stone1.bmp (both with a radius of 5 or 10). If I specify
> no colour the whole picture is black (can't see the gem at all). Am I doing the
> right thing here for an environment?
Is your light, diamond and camera inside the sphere?
> I had already changed max_trace_level from 5 to 10 (was getting warnings about
> it, 10 removed the warnings). However I further changed it to 50 and then 100,
> the only change that made was that the top of the gem got brigther and at 100 it
> was nearly completely white.
> I ran through all the finishes and interioirs in glass.inc. All the finishes
> gave results close to that of Stone3.bmp, so i kept my finish. All the interiors
> gave little to no change to the one I already had.
> One thing that I am noticing is that it spends a lot of time rendering the top
> of the gem (the part with the most clarity in Stone1.bmp) and then it chops
> through the last part in less than a second (total rendering time is 17
> seconds).
On the top, you must have a lot of reflections, while on the bottom
part, most of the rays go straight through, or only have a few
intersection with the surfaces.
> Regards
> Bidski
If your sphere is white, or any uniform colour, it don't do it's work as
an environment.
Use some mostly dark texture with some small bright areas.
You can use an image_map with map_type 1 on your sphere with some
interesting image. If you use version 3.7, you can use some high dynamic
range image to good effect.
The effects of the caustics feature are distance and ior independent,
been only dependent on the curvature of the surface. It also don't work
well if you have flat areas with sharp angles.
It's a quick and dirty way to simulate the underwater caustics play of a
pool.
Date: 11 Dec 2010 19:22:20
Message: <4d0415bc@news.povray.org>
> Regards
> Bidski
Geting prety good.
Date: 11 Dec 2010 19:45:01
Message: <web.4d041a2f1e34407486c9e330@news.povray.org>
Anything much smaller than what I have results in the diamond being nearly
invisible (maybe a result of the environment that i am mis-using?) (see
stone3.bmp).
> Proposed change:
My final product is using reflection{0.5 1 fresnel}. I think 0.1 is slightly
brighter overall.
If I leave this out I get a black diamond (most probably a result of the
environment that I am mis-using).
Can't remember what settings I had now (I think the camera and light were on the
edge of the sphere with the diamond inside it). However, I am now getting
perfectly fine results without any sphere there at all.
> an environment.
I have been trying t stay away from a patterned environment (mainly for personal
reasons), I picked white because it wasn't black or some other completely
horrible colour that I didnt want to use.
Regards
Bidski
Date: 12 Dec 2010 00:50:03
Message: <web.4d0461ef1e34407486c9e330@news.povray.org>
Does anyone know of a website or something that speaks of the optical properties
of the other gems (rubies, sappphires, emeralds, etc)? By optical properties I
basically mean the things we put in finish (diffuse, ambient, specular,
roughness, brilliance, etc).
Regards
Bidski
Date: 12 Dec 2010 08:16:51
Message: <4d04cb43$1@news.povray.org>
Am 12.12.2010 06:47, schrieb Bidski:
Finish information is all just a matter of how well the gem is polished;
except for ambient, which is a kludge to simulate diffuse illumination
coming from other objects - essentially the same job that radiosity does
much better (albeit slower).
Date: 12 Dec 2010 12:26:40
Message: <4d0505d0@news.povray.org>
> Regards
> Bidski
Much beter that the original you wanted to emulate :)
Date: 12 Dec 2010 13:50:40
Message: <4d051980$1@news.povray.org>
Bidski wrote:
> can POV-Ray do transparent backgrounds?
yes, render with command line option +ua (and a file
format such as PNG that supports transparency). If the
ray doesn't hit an object the pixel will be transparent,
although there are some tricky details regarding things
like anti-aliased pixels. And with a transparent object,
there may be additional issues such as not correctly
showing refracted parts of the new background.
