POV-Ray : Newsgroups : povray.newusers : object variables for rending similar objects differently Server Time
26 Mar 2026 11:20:59 EDT (-0400)
  object variables for rending similar objects differently (Message 1 to 3 of 3)
Subject: object variables for rending similar objects differently
Date: 1 Nov 2010 07:20:01
Message: <web.4ccea11b6541604eb52264400@news.povray.org>
Hello!
I'm wondering if there's a way to supply variables\values to a union object to
alter the way it is rendered. I'm not sure if I've worded that correctly, so
consider the code below. I'm trying to rotate the top box on the second figure,
but leave the first figure as-is. Is something like this possible or would I
need completely separate declarations for each "pose".
Thanks for any help you can offer.
-nip
Sample code:
#declare Tilted = 0.0;
#declare Figure = union {
    box {
        <0, 0, 0>, <1, 1, 1>
        pigment { Green }
    box {
        pigment { Blue }
        #if (Tilted > 0)
            rotate z*15
        translate y*1
object { Figure }
object {
    #declare Tilted = 1; //this does not make the right blue box rotate
    Figure
    translate <2, 0, 0>
    location <5, 1, -5>
    look_at <0, 1, 3>
light_source {
    <5, 1, -5>
    color rgb <1, 1, 1>
Subject: Re: object variables for rending similar objects differently
Date: 1 Nov 2010 07:45:46
Message: <4ccea86a$1@news.povray.org>
On 11/01/2010 08:14 AM, nip wrote:
> Hello!
> -nip
> Sample code:
>     box {
>         pigment { Green }
>     box {
>         pigment { Blue }
>         #if (Tilted > 0)
>             rotate z*15
>         #end
>         translate y*1
> object { Figure }
> object {
>     Figure
>     translate <2, 0, 0>
> camera {
>     location <5, 1, -5>
>     look_at <0, 1, 3>
> light_source {
>     <5, 1, -5>
>     color rgb <1, 1, 1>
a macro is what you need:
http://wiki.povray.org/content/Documentation:Reference_Section_2.6#The_.23macro_Directive
you problem is a simple one so I'll get you started, give this a whirl:
#macro Figure (Tilted)
union {
    box {
        pigment { Green }
    box {
        pigment { Blue }
        #if (Tilted > 0)
            rotate z*15
        translate y*1
object { Figure (0)  }
object { Figure (1) translate <2,0,0> }
Date: 1 Nov 2010 16:45:01
Message: <web.4ccf263dc5b54ea8b52264400@news.povray.org>
> > Hello!
> > -nip
> > Sample code:
> >     box {
> >         pigment { Green }
> >     box {
> >         pigment { Blue }
> >         #if (Tilted > 0)
> >             rotate z*15
> >         #end
> >         translate y*1
> > object { Figure }
> > object {
> >     Figure
> >     translate <2, 0, 0>
> > camera {
> >     location <5, 1, -5>
> >     look_at <0, 1, 3>
> > light_source {
> >     <5, 1, -5>
> >     color rgb <1, 1, 1>
> union {
>     box {
>         pigment { Green }
>     box {
>         pigment { Blue }
>         #if (Tilted > 0)
>             rotate z*15
>         #end
>         translate y*1
> #end
Excellent! Macros look pretty powerful. Thanks
