POV-Ray : Newsgroups : povray.newusers : Help with arc Server Time
15 Dec 2025 17:34:08 EST (-0500)
  Help with arc (Message 1 to 5 of 5)
Subject: Help with arc
Date: 23 Jul 2010 07:05:00
Message: <web.4c49771ad7a2dbc37f6843480@news.povray.org>
Hi All,
I'm new to POV-Ray and I'm trying to create a "bent cylinder" or a thick arc
that passes through 5 points. I think that a quadratic spline might do it, but
I'm not sure exactly how to go about it... The five points I would like it to go
through are the following and I would like are:
sphere {
<0,0,0>, 0.400000
translate <19.857401,2.216100,1.258800>
pigment { rgbt <0.000000,0.000000,1.000000,0.000000> }
sphere {
<0,0,0>, 0.400000
translate <21.089600,9.403000,4.822600>
sphere {
<0,0,0>, 0.400000
translate <19.241899,0.224900,9.172700>
pigment { rgbt <0.000000,0.000000,1.000000,0.000000> }}
sphere {
<0,0,0>, 0.400000
translate <11.432800,2.216100,11.043700>
sphere {
<0,0,0>, 0.400000
translate <10.200600,9.403000,7.479900>
Help please!
Thanks in Advance,
Jack
Subject: Re: Help with arc
Date: 23 Jul 2010 15:08:23
Message: <4c49e8a7$1@news.povray.org>
> Hi All,
> sphere {
> <0,0,0>, 0.400000
> translate<19.857401,2.216100,1.258800>
> pigment { rgbt<0.000000,0.000000,1.000000,0.000000>  }
> sphere {
> <0,0,0>, 0.400000
> translate<21.089600,9.403000,4.822600>
> sphere {
> <0,0,0>, 0.400000
> translate<19.241899,0.224900,9.172700>
> pigment { rgbt<0.000000,0.000000,1.000000,0.000000>  }}
> sphere {
> <0,0,0>, 0.400000
> translate<11.432800,2.216100,11.043700>
> sphere {
> <0,0,0>, 0.400000
> translate<10.200600,9.403000,7.479900>
> Help please!
> Thanks in Advance,
> Jack
You can use the sphere_sweep primitive. Try the b_spline and
cubic_spline. Be warned that those splines uses the first and last
points as control points and that the actual ubject don't reatch those.
You can also use the spline feature and use it to place many spheres and
short cylinders to create your curve.
The quadratic_spline neede 2 control points. The natural_spline may be
beter suited to your need. Please read the documentation carefuly and
take a look at some sample scenes that use that feature. The
splinefollow.pov scene from the animations folder is a good sample to start.
Once the spline is defined, you travel through it using a #while() loop.
Date: 23 Jul 2010 15:45:00
Message: <web.4c49f12baac6f43cf99d05c80@news.povray.org>
Alain wrote:
> > Hi All,
[snip]
[snip]
I just wrote something similar and found a sphere_sweep with a cubic_spline
works well by making the first point equal to the second, and the next-to-last
equal to the last.  In my case I was only connecting (for example) two corner
points c1 and c2 through a side point s5 in two dimensions.  The radius of the
"bent cylinder" is r.
sphere_sweep{ cubic_spline 5
<c1.x, c1.y, 0>, r
<c1.x, c1.y, 0>, r
<s5.x, s5.y, 0>, r
<c2.x, c2.y, 0>, r
<c2.x, c2.y, 0>, r
However, I have not figured out why this sometimes makes some odd loopy
artifacts.
Date: 24 Jul 2010 16:59:29
Message: <4c4b5431$1@news.povray.org>
> Alain wrote:
>>> Hi All,
> [snip]
> [snip]
> <c1.x, c1.y, 0>, r
> <c1.x, c1.y, 0>, r
> <s5.x, s5.y, 0>, r
> <c2.x, c2.y, 0>, r
> <c2.x, c2.y, 0>, r
> artifacts.
Up until the 2 last 3.7 betas, the sphere_sweep had some bugs causing
all sort of artefacts.
Also, if you have a control point coincident with an end point, it can
missbehave. It can work some times, and have some strange effects at others.
Date: 29 Jul 2010 08:35:01
Message: <web.4c517532aac6f43c7f6843480@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Alain wrote:
> >>> Hi All,
> > [snip]
> > [snip]
[snip]
> Alain
Thanks for your help!
I've got it working now to some extent based on the splinefollow example, I can
get the cylinder to start at one point (purple top), trace through the others in
order but not have it end at the point I would like (purple bottom). It seems to
go through no matter what I do...! Could it be a problem with the while? the
file is pasted below.
Thanks in advance,
Jack
#include "math.inc"
#include "transforms.inc"
location < 0.0, 0.0, 90.204815 >
right -4/3*x
angle 45.000000
look_at < 0, 0, 0 >
light_source {< 1,2,-2>*1000, color 1.0}
light_source {<-1,2, 1>*1000, color 0.7 shadowless}
#declare MySpline1 =
spline {
   cubic_spline
      -2, <15.646700,9.031800,1.374400>,
         -1, <15.646700,9.031800,1.374400>,
    00, <15.646700,9.031800,1.374400>,
   01, < 18.688101,13.562600,7.479900>,
   02, < 11.847900,16.089001,11.043700>,
   03, < 6.218900,10.321700,9.172700>,
   04, < 7.635600,8.793100,1.258800>,
   05, <13.243600,4.132500,4.822600>,
   06, < 15.646700,9.031800,10.928100>,
     12, <15.646700,9.031800,10.928100>,
   13, < 15.646700,9.031800,10.928100>,
// The yellow wire that shows the spline path.
union {
   #declare C = 0;
   #declare Cmax= 500;
   #while (C<=Cmax)
      #declare Value1 = C/Cmax*11;
      #declare Value2 = (C+1)/Cmax*11;
      #declare Point1 = -0.5*y+MySpline1(Value1);
      #declare Point2 = -0.5*y+MySpline1(Value2);
      sphere {Point1, 0.4}
      cylinder {Point1, Point2, 0.4}
      #declare C = C+1;
   pigment {color <1,1,0>}
   matrix < 0.440493, -0.865077, 0.240017,
         -0.873508, -0.474711, -0.107857,
         0.207243, -0.162147, -0.964758,
         0, 0, 0 >
translate< 0.541643, 18.311583, 3.783246 >
object {
#declare _WLVP_line_width = 0.02;
#declare _WLVP_dot_size   = 0.03;
#declare _WLVP_text_depth = 0.0;
#declare _WLVP_text_scale = 0.3;
#declare _WLVP_finish = finish { reflection 0.15 brilliance 6 diffuse 0.90
ambient 0.15 phong 0.5 phong_size 10 metallic specular 0.0 }
union {
//purple top
sphere {
<0,0,0>, 1.000000
translate <15.646700,9.031800,1.374400>
pigment { rgbt <0.501961,0.000000,0.501961,0.000000> }
finish { _WLVP_finish }
//red 5
sphere {
<0,0,0>, 0.500000
translate <13.243600,4.132500,4.822600>
pigment { rgbt <1.000000,0.000000,0.000000,0.000000> }
//red 4
sphere {
<0,0,0>, 0.600000
translate <7.635600,8.793100,1.258800>
//red 3
sphere {
<0,0,0>, 0.700000
translate <6.218900,10.321700,9.172700>
//red 2
sphere {
<0,0,0>, 0.800000
translate <11.847900,16.089001,11.043700>
//red 1
sphere {
<0,0,0>, 0.900000
translate <18.688101,13.562600,7.479900>
//purple bottom
sphere {
<0,0,0>, 0.400000
translate <15.646700,9.031800,10.928100>
         0, 0, 0 >
