POV-Ray : Newsgroups : povray.newusers : Overriding the transparency of a union Server Time
18 Nov 2025 23:20:48 EST (-0500)
  Overriding the transparency of a union (Message 1 to 4 of 4)
Subject: Overriding the transparency of a union
Date: 13 May 2010 17:30:00
Message: <web.4bec6e3aa5df0a1dc5768ac0@news.povray.org>
I saw a couple older posts about this and am hoping there may be a new feature
that would make things easier.
I am doing a complex animation where certain parts fade in and out. The parts
are made of unions of components with each components having its own
texture/pigment. I would like to just fade the transparency for the whole union.
Is there a way to do this at the union level or do I need to embed a
transparency clock down to each component.
Thanks
Subject: Re: Overriding the transparency of a union
Date: 13 May 2010 19:16:44
Message: <4bec885c$1@news.povray.org>
Am 13.05.2010 23:25, schrieb tensor:
The latter.
You'll probably also get unexpected behavior regarding hidden surfaces
(depending on what you really want to achieve), as they will become
partially visible while the object fades out.
Maybe the focal blur mechanism of MegaPOV could be misused to achieve
what you want.
Date: 13 May 2010 21:14:10
Message: <4beca3e2$1@news.povray.org>
> Thanks
No, not directly as each texture or pigment assigned to any individual
component override the global union's texture, including any filter and
transmit.
You can use a variable to set the transparency. If several/all elements
have the same transparency level, then you only need to set one variable.
Also, you'll probably need to change from union to merge if you don't
want to see the internal surfaces that are hiden when you don't have
transparency.
Date: 14 May 2010 09:05:00
Message: <web.4bed49e4bae6cdf77b41f88c0@news.povray.org>
> > Thanks
> transmit.
> transparency.
> Alain
Thank you both for the information.
