POV-Ray : Newsgroups : povray.newusers : Using conditional expression in functions. How to write step functions? Server Time
26 Mar 2026 13:13:59 EDT (-0400)
  Using conditional expression in functions. How to write step functions? (Message 1 to 9 of 9)
Subject: Using conditional expression in functions. How to write step functions?
Date: 18 Dec 2009 11:25:01
Message: <web.4b2babbe34012ef28bf23f70@news.povray.org>
Is there a way to use an conditional expression in function?
For example, how can I write something like that (the code isn't compilable):
#local  =
function(a) {
  #if (a < .1)
    1
  #else
    0
The compiler says that it doesn't know anything about "a".
Ok, the "#if" condition is calculated only once, but function will be calculated
many times. I try to rewrite the function:
#local  =
function(a) {
  (a < .1) ? 1 : 0
But the compiler says that "Expected 'operator', ? found instead". But as I know
the question sign is a float operator.
Where I'm wrong? And how to write for example step functions? Shall I use the
"select" function?
Unfortunatly I can't see a good way for modelling function like this:
___----_-__- with the "select" function.
Subject: Re: Using conditional expression in functions. How to write step functions?
Date: 18 Dec 2009 11:41:06
Message: <4b2bb0a2@news.povray.org>
> #local  =
> function(a) {
>   #if (a < .1)
>     1
>   #else
>     0
>   #end
  Because 'a' is not a declared identifier. (Function parameters have nothing
to do with declared identifiers and are invisible to any # commands.)
> #local  =
> function(a) {
>   (a < .1) ? 1 : 0
  The ?: syntax is not supported by user-defined functions.
> Shall I use the "select" function?
  That's what it was created for.
  If you can express it with ?:, you can express it with select().
Date: 18 Dec 2009 14:05:01
Message: <web.4b2bd247be6ce51d8bf23f70@news.povray.org>
Thanks for a fast answer. =)
Unfortunatly the best way is express it with the something like case statement,
not with the "select" function.
I think that SDL will contain constructions for situations like this. May be a
feature or a feature request is exists in the beta version?
Date: 18 Dec 2009 15:24:06
Message: <4b2be4e6@news.povray.org>
  But it's not like it's *impossible* to express the same thing with select().
Date: 18 Dec 2009 18:06:40
Message: <4b2c0b00$1@news.povray.org>
I just hacked something up which might do what you want,
with the following limitations
1. No nesting of fswitch blocks
2. Quotes required around all subexpressions (except plain numbers)
Basically, it is a set of macros which will write an include
file containing the nested select statements.
#macro fswitch(CONTROL)
#declare CASE_CONTROL = CONTROL;
#declare CASE_COUNTER = 0;
#fopen   CASE_FILE "switch_tmp.inc" write
#macro fcase(CASE,VALUE)
#declare CASE_COUNTER = CASE_COUNTER + 1;
#write(CASE_FILE,"select((",CASE_CONTROL,")-(",CASE,"),",VALUE,",\n")
#macro fdefault(VALUE)
#write(CASE_FILE,VALUE)
#while(CASE_COUNTER > 0)
   #write(CASE_FILE,")")
   #declare CASE_COUNTER = CASE_COUNTER - 1;
#fclose CASE_FILE
#include "switch_tmp.inc"
function(a,b)
   fswitch("a")
   fcase(0.1,"1")
   fcase(0.5,"b")
   fdefault("0")
Date: 18 Dec 2009 18:07:10
Message: <4b2c0b1e$1@news.povray.org>
Unless you run into some sort of nesting limit, maybe ;)
Date: 18 Dec 2009 19:10:00
Message: <web.4b2c1926be6ce51da049a19e0@news.povray.org>
> #local  =
> function(a) {
>   #if (a < .1)
>     1
>   #else
>     0
>   #end
#declare StepFn = function(A) { select(A - 0.1, 1, 0) }
Tor Olav
http://subcube.com
Date: 19 Dec 2009 03:06:00
Message: <EvyzVLOflILLFwtm@econym.demon.co.uk>
That looks something like what I do here:
http://www.econym.demon.co.uk/isotut/arrays.htm
Mike Williams
Gentleman of Leisure
Date: 19 Dec 2009 11:10:01
Message: <web.4b2cfa77be6ce51d8bf23f70@news.povray.org>
There are interesting macroses fswitch, fcase and fdefault. It is to be
regretted that those macroses can not work without an additional file.
