POV-Ray : Newsgroups : povray.newusers : <no subject> Server Time
7 Apr 2026 19:26:57 EDT (-0400)
  <no subject> (Message 1 to 3 of 3)
Subject: <no subject>
Date: 4 Oct 2009 06:30:01
Message: <web.4ac87901c23a6d9d001f37b0@news.povray.org>
Hello. Is there any way in POV-Ray to change the default output file type?
Thanks.
Subject: Re: <no subject>
Date: 4 Oct 2009 11:14:22
Message: <4ac8bbce@news.povray.org>
  Edit povray.ini and add "+fn" there.
Date: 4 Oct 2009 17:43:08
Message: <4ac916ec$1@news.povray.org>
> Thanks.
In the povray.ini file, add:
+fn to output as PNG. The most common.
+ft for normal TGA.
+fc for compressed TGA using RLE encoding.
+fp for PPM.
You can also use the same on the command line if you need to. For
example, when generating the image for a hight_field using hf16 option,
you should add +ft or +fc on the command line.
