POV-Ray : Newsgroups : povray.newusers : Auto render off (but still on) Server Time
28 Sep 2024 16:21:31 EDT (-0400)
  Auto render off (but still on) (Message 1 to 8 of 8)
Subject: Auto render off (but still on)
Date: 28 Sep 2009 15:50:00
Message: <web.4ac1133eb716f01998b5d1e80@news.povray.org>
I've a problem with the auto-render feature, I disabled it but every time I
double-click on a pov-ray file, it just opens pov-ray and still start rendering.
I would like to open every file just into the Editor and be able to start the
rendering only manually.
I've checked and the Autorender is 0 (off).
Could you please help me ?
Thanks a lot.
Subject: Re: Auto render off (but still on)
Date: 28 Sep 2009 16:30:00
Message: <web.4ac11bd1a3ae398e81c811d20@news.povray.org>
"Darats" <damien___@hotmail.com> wrote:
> Hi,
> Thanks a lot.
The Auto-Render setting under the Render file menu is for the File Queue (see
1.5.7.6 in the docs)
Assuming you are using windows (likely), it sounds like it is just your file
association.
When you left click on the file there should be 2 options with one in bold:
Edit with in POV-Ray
Render with POV-Ray
the bolded one is the default and it sound like it's set to render.
If you don't know how to change this:
In Windows Explorer, go to the menu item [Tools/Folder Options...]
In the "File Types" tab, find POV extension, click "Advanced"
Select the "Edit in POV-Ray" action and click "set default"
Done!, click OK
-tgq
Date: 28 Sep 2009 17:30:00
Message: <web.4ac12a36a3ae398e98b5d1e80@news.povray.org>
> > Hi,
> > Thanks a lot.
> association.
> Render with POV-Ray
> Done!, click OK
> -tgq
Thanks a lot, I see what you means with XP, but in fact I'm running Seven. Do
you have any clue haw to do it with this OS (I think I should be the same as
Vista).
Date: 28 Sep 2009 19:30:01
Message: <web.4ac145dda3ae398ec67b294d0@news.povray.org>
> > > Hi,
> > > Thanks a lot.
> > association.
> > Render with POV-Ray
> > Done!, click OK
> > -tgq
> Vista).
No idea.  I windows explorer not the same or similar?  I'm familiar with XP, not
Vista or 7.
-tgq
Date: 29 Sep 2009 04:24:26
Message: <4ac1c43a$1@news.povray.org>
"Darats" <damien___@hotmail.com> wrote in message
news:web.4ac12a36a3ae398e98b5d1e80@news.povray.org...
>> > Hi,
>> > time I
>> > rendering.
>> > start the
>> > Thanks a lot.
>> (see
>> file
>> association.
>> bold:
>> Render with POV-Ray
>> Done!, click OK
>> -tgq
> Do
> as
> Vista).
On my Vista system 'edit' is already the default right-click option for .pov
files and I don't want to mess with that in case Windows screws everything
up. I therefore didn't try this, but the third option mentioned on the
following page seems to me like it might do what you want. Of course
downloading a utility off the Internet to manipulate your operating system
settings carries the standard health warning.
http://www.annoyances.org/exec/show/article02-500
Chris B
Date: 29 Sep 2009 04:30:53
Message: <4ac1c5bd$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4ac1c43a$1@news.povray.org...
> Of course downloading a utility off the Internet to manipulate your
> operating system settings carries the standard health warning.
I've also just found a review of alternative utilities for this sort of
thing:
http://forums.techarena.in/tips-tweaks/989159.htm
Chris B.
Date: 29 Sep 2009 08:55:01
Message: <web.4ac2032ca3ae398e81c811d20@news.povray.org>
> >> > Hi,
> >> > time I
> >> > rendering.
> >> > start the
> >> > Thanks a lot.
> >> (see
> >> file
> >> association.
> >> bold:
> >> Render with POV-Ray
> >> Done!, click OK
> >> -tgq
> > Do
> > as
> > Vista).
> Regards,
> Chris B
I should think that you shouldn't need a third party program to do this.  It was
so simple in XP and earlier (if you knew where to go).  There has to be the
abaility somewhere in Vista (and 7) to do this.  Have a look at the solutions
offered here: (method 1 or 3 would seem the appropriate ones perhaps)
http://www.mydigitallife.info/2008/06/20/how-to-edit-or-change-file-type-or-extension-associations-default-programs-in-
windows-vista/
-tgq
Date: 29 Sep 2009 09:10:01
Message: <web.4ac2066fa3ae398e81c811d20@news.povray.org>
Oh, try here.  This points you to the Control Panel - Default Programs.  Would
seem a likely place.  (I'm assuming Win7 is same or similar to Vista)
http://articles.techrepublic.com.com/5100-10878_11-6172036.html
-tgq
