POV-Ray : Newsgroups : povray.newusers : I did something wrong but I don't know what Server Time
7 Apr 2026 19:26:34 EDT (-0400)
  I did something wrong but I don't know what (Message 1 to 3 of 3)
Subject: I did something wrong but I don't know what
Date: 16 Sep 2009 12:00:00
Message: <web.4ab10a6cf7b77cc2d48f0ac30@news.povray.org>
and now in the edit menu the entries for undo and redo are permanently grayed
out so I can't use those features anymore, it is as if the history file is
somewhat damaged or has lost its right permessions?
Subject: Re: I did something wrong but I don't know what
Date: 16 Sep 2009 13:39:57
Message: <4ab122ed$1@news.povray.org>
Try "Editor / Editor Preferences..."; in the dialog, go to the "Misc"
tab. In the bottom-right of that pane, there's a "Max undoable actions"
section; make sure it's set to "Unlimited", or "Limited to" something
sufficiently larger than 0.
If it already appears to be set to a sane value, you may try changing
it, closing and re-starting POV-Ray, then setting it back to "Unlimited"
and again restarting POV-Ray. Just in case something in the undo
mechanism got "jammed", this might "shake" it enough so that things fall
  back into place.
Date: 17 Sep 2009 05:45:01
Message: <web.4ab204ef98a9a58288b2179b0@news.povray.org>
>   back into place.
I went to the "Max undoable actions" and I saw that is was set to "limited to 0"
(how that got there is a complete mystery to me). I set it to Unlimited,
restarted
povray and everything works fine now.
Thanks a lot for your help,
Marc.
