POV-Ray : Newsgroups : povray.newusers : cylinder walls Server Time
19 Nov 2025 02:33:26 EST (-0500)
  cylinder walls (Message 1 to 5 of 5)
Subject: cylinder walls
Date: 26 Aug 2009 04:55:01
Message: <web.4a94f7e9b9b7383db357110e0@news.povray.org>
How could I create a hollow cylinder but with thicker walls?
Subject: Re: cylinder walls
Date: 26 Aug 2009 05:47:39
Message: <4a9504bb@news.povray.org>
You need to cut a hole into a solid cylinder using CSG:
difference {
   #local Dir = vnormalize(B-A);
   cylinder { A,B,Radius }
   cylinder { A+Dir*Thickness,B-Dir*Thickness,Radius-Thickness }
where A and B are center coordinates of the top and bottom,
respectively, and Radius and Thickness are the outer cylinder radius and
the thickness of the cylinder, respectively.
This will create an airtight hollow cylinder. To have open ends, instead
use:
difference {
   cylinder { A-Dir*0.01,B+Dir*0.01,Radius-Thickness }
Date: 26 Aug 2009 06:15:01
Message: <web.4a9509f794c8b39fb357110e0@news.povray.org>
could you show me a small example, im trying to play around with the variables
but its not working, get a huge shape
difference {
   #local Dir = vnormalize(1-2);
   cylinder { 2,1,3 }
   cylinder { 2-Dir*0.01,1+Dir*0.01,3-1 }
Date: 26 Aug 2009 07:31:16
Message: <4a951d04$1@news.povray.org>
Make sure to use vectors for A and B.
For instance:
   #local A = <0,0,0>;
   #local B = <0,2,0>;
   #local Radius = 0.8;
   #local Thickness = 0.2;
   difference {
or, with all the math already worked out and hard-coded:
   difference {
     cylinder { <0,0,0>, <0,2,0>, 0.8 }
     cylinder { <0,-0.02,0>, <0,2.02,0>, 0.6 }
Date: 27 Aug 2009 19:34:36
Message: <4a97180c$1@news.povray.org>
#macro Pipe(P1, P2, r1, r2)
  #local _P3 = P1 - 0.1*(P2-P1); // V1 - 0.1*V2
  #local _P4 = P1 + 1.1*(P2-P1); // V1 + 1.1*V2
  difference {
    cylinder {P1,P2,r1}
    cylinder {_P3,_P4,r2}
// example
Pipe(<0,0,0>,<0,1,0>,0.5,0.45)
