![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How could I create a hollow cylinder but with thicker walls?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You need to cut a hole into a solid cylinder using CSG:
difference {
#local Dir = vnormalize(B-A);
cylinder { A,B,Radius }
cylinder { A+Dir*Thickness,B-Dir*Thickness,Radius-Thickness }
where A and B are center coordinates of the top and bottom,
respectively, and Radius and Thickness are the outer cylinder radius and
the thickness of the cylinder, respectively.
This will create an airtight hollow cylinder. To have open ends, instead
use:
difference {
cylinder { A-Dir*0.01,B+Dir*0.01,Radius-Thickness }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
could you show me a small example, im trying to play around with the variables
but its not working, get a huge shape
difference {
#local Dir = vnormalize(1-2);
cylinder { 2,1,3 }
cylinder { 2-Dir*0.01,1+Dir*0.01,3-1 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Make sure to use vectors for A and B.
For instance:
#local A = <0,0,0>;
#local B = <0,2,0>;
#local Radius = 0.8;
#local Thickness = 0.2;
difference {
or, with all the math already worked out and hard-coded:
difference {
cylinder { <0,0,0>, <0,2,0>, 0.8 }
cylinder { <0,-0.02,0>, <0,2.02,0>, 0.6 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
#macro Pipe(P1, P2, r1, r2)
#local _P3 = P1 - 0.1*(P2-P1); // V1 - 0.1*V2
#local _P4 = P1 + 1.1*(P2-P1); // V1 + 1.1*V2
difference {
cylinder {P1,P2,r1}
cylinder {_P3,_P4,r2}
// example
Pipe(<0,0,0>,<0,1,0>,0.5,0.45)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
