POV-Ray : Newsgroups : povray.newusers : POV-Ray Parse error Server Time
11 Jan 2026 23:24:08 EST (-0500)
  POV-Ray Parse error (Message 1 to 4 of 4)
Subject: POV-Ray Parse error
Date: 18 Aug 2009 08:25:00
Message: <web.4a8a9d32d6b7ccda53d4d41d0@news.povray.org>
I'm relatively new with POV-ray. i use it to render 3d images with eagle 3D and
everything has been working great. just recently i updated my POV-Ray to 3.7
beta 33. Now every time i try to render a PCB, even the existing ones, i get an
error that says "Parse Error: End of file reached but #end expected."  why is
this? any help would be great, i would really appreciate it.
Subject: Re: POV-Ray Parse error
Date: 18 Aug 2009 09:07:44
Message: <4a8aa7a0$1@news.povray.org>
"Dan" <djg### [at] psuedu> wrote in message
news:web.4a8a9d32d6b7ccda53d4d41d0@news.povray.org...
> 3D and
> 3.7
> get an
> is
That's odd. I've been on beta 33 for a while and not seen that. Usually that
error would mean you've got a #while, #if or #switch statement without a
corresponding #end statement, but if that were the case you'd normally get
the same error on 3.6.
Do you get this error with a very minimal scene, such as:
camera {location <0, 0,-1> look_at <0,0,0>}
light_source {<1,5,-1> color rgb 1}
sphere {0,0.5 pigment {rgb <1,0,0>}}
If so, then I'd say your installation is corrupt and I'd recommend
re-installing. OTOH, if this minimal render works, then I'd look for
something wrong with any code that is common to all of your scenes, such as
an #include file that you add to all scenes, or a piece of SDL that you
religiously copy into all scenes and see if you can spot something wrong
there. You should be able to quickly narrow it down by adding any such code
into the minimal scene file one piece at a time.
Chris B.
Date: 18 Aug 2009 11:25:00
Message: <web.4a8ac7a5998f449453d4d41d0@news.povray.org>
> Regards,
> Chris B.
Thanks chris, i had to reinstall the program and move a few .inc and .ini files
around..it works great now
Date: 18 Aug 2009 12:32:14
Message: <4a8ad78e$1@news.povray.org>
Dan wrote:
> just recently i updated my POV-Ray to 3.7 beta 33.
As a new user, you should be using a release version, in this case POV-Ray
3.6.2, not a POV-Ray beta version, which is for testing, and not for general
use!
	Thorsten
