POV-Ray : Newsgroups : povray.newusers : sin in sor or lathe Server Time
28 Sep 2024 16:18:25 EDT (-0400)
  sin in sor or lathe (Message 1 to 4 of 4)
Subject: sin in sor or lathe
Date: 5 Aug 2009 16:40:00
Message: <web.4a79ec1572ab07797576e0550@news.povray.org>
I have a strange problem, where I were not able to find a solution on the net so
far.
When I use a "sin(...)" in a sor- or lathe-object, the argument of the function
cannot exceed Pi.
For Example:
sor{5,
     <1,2>,
     <sin(3),3>,
     <sin((1.001-0.001)*Pi),5>,
     <4,6>,
     <1,7>
     pigment{color Blue}
this works fine, but with
sor{5,
     <1,2>,
     <sin(3),3>,
     <sin(1.001*Pi),5>,
     <4,6>,
     <1,7>
     pigment{color Blue}
I get the error message:
"Parse error: Incorrect point in sor."
I used a self-defined Pi in this example, but even without "sin(3)" works,
"sin(3.15)" and bigger arguments do not work.
Even if I have a macro which calculates the sine
#macro Sine(x)
#declare Global_Value=sin(x);
and put "Global_Value" within the brackets of the coordinates in sor (or lathe)
I have the exact same effect.
If I use a sine for the position of a light source for example, I can put in
every argument.
I am using Povray 3.6.1 from the ubuntu repository and I also tried it with the
same result on a windows machine and Povray 3.6.2.
Any suggestions?
McMinty
Subject: Re: sin in sor or lathe
Date: 5 Aug 2009 17:20:10
Message: <4a79f78a$1@news.povray.org>
McMinty schrieb:
> Hi,
> far.
> cannot exceed Pi.
This is not a problem with the sin function per se, but with its
function result becoming negative, which sor and lathe will refuse to
accept in the X coordinate. For instance, the following should work
perfectly:
sor{5,
    <1,2>,
    <1+sin(3),3>,
    <1+sin(1.001*Pi),5>,
    <4,6>,
    <1,7>
    pigment{color Blue}
Date: 6 Aug 2009 02:45:23
Message: <4a7a7c03@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4a79f78a$1@news.povray.org...
> McMinty schrieb:
>> Hi,
>> function
>> cannot exceed Pi.
> This is not a problem with the sin function per se, but with its function
> result becoming negative, which sor and lathe will refuse to accept in the
> X coordinate. For instance, the following should work perfectly:
> sor{5,
>    <1,2>,
>    <1+sin(3),3>,
>    <4,6>,
>    <1,7>
>    pigment{color Blue}
You can also use  abs(sin(,,,))  if you want the points to effectively
'straddle' the y-axis as an alternative to thickening out the core of the
generated object.
Chris B.
Date: 6 Aug 2009 03:30:01
Message: <web.4a7a85bd3d938f37937b60f60@news.povray.org>
Thanks,
this shows again that I should read the docs more carefully.
McMinty
