POV-Ray : Newsgroups : povray.newusers : "difference" with a composed object Server Time
19 Nov 2025 02:23:30 EST (-0500)
  "difference" with a composed object (Message 1 to 5 of 5)
Subject: "difference" with a composed object
Date: 18 Jul 2009 14:30:01
Message: <web.4a621451d328db22dc80fc610@news.povray.org>
I want to have a thin box (or plate) with a lot of equaly spaced holes inside.
Basically I know how to do it and it already worked, but I needed ~17min to
render the picture, so I hope there is a better (faster) way to reach my goal.
Here is what I did:
#include "textures.inc"
#declare i=0; //just two counters
#declare j=0;
//here follows the box:
#declare pure_table=box{<0,0,0>, <-362, 1, 150>
 texture{
  pigment{color rgb<0.7,0.7,0.7>}
  normal{wrinkles scale 0.02}
  finish{phong 1.0 phong_size 120 metallic reflection 0.3 brilliance 2}
//one Hole is defined here:
#declare hole=sphere{<0,0.5,0>,0.7 pigment{color Black}};
//just a few constants
#declare hole_xoffset=4.75;
#declare hole_zoffset=3.75;
#declare holes_x=141;
#declare holes_z=57;
//this is the macro that gives me all the holes I want to have;
#macro all_holes()
union{#while(i< holes_x)
  #while(j<holes_z)
      object{hole translate <-hole_xoffset-i*2.5,0,hole_zoffset+j*2.5>}
 #declare j = j + 1;
  #declare j=0;
  #declare i =i + 1;
#end}
//here I draw the difference between the table and the holes:
difference{object{pure_table}
object{all_holes()}}
//top-view camea
    location <-180, 90, 75>
    look_at <-160, 0, 70>
light_source {
    <-300, 90, 75>
    color White
/*this light source is just the test for me to see, if the holes are really
through the table*/
light_source {
  <-300,-70,75>
  color Blue
plane{<0,1,0>,-100
      pigment{
    gradient x
    color_map{
        [0.8 rgb<0.9,0.9,0.9>  ]
        [1.0 rgb<0.5,0.5,0.5>  ]
   turbulence 1
Another thing I tried was not to have the macro but a normal definition
#declare all_holes=#while ...... #end
My Problem with this solution was, that I alway got error messages from the
POVRay-Parser when I ended the line with a ";"
But without the ";" all the spheres were actually drawn which is the complete
opposite from the thing I want to have.
Only the rendering time was very short....
Every advice or comment is appreciated.
Thanks
Subject: Re: "difference" with a composed object
Date: 18 Jul 2009 14:49:46
Message: <4a62194a$1@news.povray.org>
"McMinty" <nomail@nomail> wrote in message
news:web.4a621451d328db22dc80fc610@news.povray.org...
> Hi,
> inside.
> to
> goal.
It turns out to be a lot quicker to create a small block with a hole in it
and assemble those blocks.
Mike Williams has written up a choice of solutions to this problem at
http://www.econym.demon.co.uk/holetut/index.htm
> ... snip ...
> the
> complete
To declare your holes in this way you would still need the 'union' statement
that you had in your macro. So you could do:
#declare all_holes = union{
  #while
  ... add your objects into the union here ...
}  // end of union
Chris B.
Date: 18 Jul 2009 15:05:00
Message: <web.4a621c7c5ea8f953707a5c110@news.povray.org>
I *think* it should also speed things up if you don't subtract individual holes,
but multiple unions of holes - or maybe even unions of unions of holes. The idea
is to enforce a nested hierarchy of bounding boxes this way, which is what's
actually missing with a difference containing hundreds of individual objects.
Date: 18 Jul 2009 15:52:21
Message: <4a6227f5$1@news.povray.org>
> Hi,
> Here is what I did:
> #declare j=0;
>  texture{
You do this only if you want the sides of the holes to actualy be black.
Also, it's more effecient to apply any texture to an union rather that
to each of the components.
> #macro all_holes()
>   #while(j<holes_z)
>  #declare j = j + 1;
>       #end
>   #declare j=0;
>   #declare i =i + 1;
> #end
If you want a distinct texture for the holes, add it here.
> #end
> //top-view camea
> camera {
> light_source {
>     <-300, 90, 75>
>     color White
> through the table*/
> light_source {
>   <-300,-70,75>
>   color Blue
> plane{<0,1,0>,-100
>       pigment{
>     gradient x
>     color_map{
>    turbulence 1
> Thanks
Normaly, in that case, the best way is to first declare a small box with
a single hole.
Then, you assemble many of those small box with a single hole into a
large composite object.
Things to do and dont do:
Don't apply any texture to your small boxes, nor to the object used to
make the hole.
Do apply the texture to the complete usion.
Why this is way faster:
When you use a difference where you remove a large number of objects
from a single one, the bounding becomes VERY ineficient. For each ray
that can encounter your object, the base object and each and every holes
must be tested.
When you use many small components in an union, each small box-hole
component have it's own bounding, and you only have to test very few
components for each ray. This will save you a conciderable amount of time.
Question of "style": you should always use an opper-case character as
the first character of any user defined variable.
"x", "y", "z", "t", "clock", "gray", "grey" where once not reserved
variables names. When they became reserved, it played havok with many
scenes that used them as user variables...
Who know, "i", "j", "k" may become reserved at some time.
Date: 2 Aug 2009 09:40:01
Message: <web.4a7596be5ea8f953d58c2e280@news.povray.org>
Hey,
thanks for all the comments and helpful tips.
It helped me a lot.
cu
Mcminty
