POV-Ray : Newsgroups : povray.newusers : conditional statements Server Time
13 Mar 2026 18:17:51 EDT (-0400)
  conditional statements (Message 1 to 9 of 9)
Subject: conditional statements
Date: 17 Jul 2009 04:50:00
Message: <web.4a603abbcc998528ff025eb50@news.povray.org>
is it possible to write
 #if (DoorModel == model_101)   in an if statement
and  in switches
  #switch(DoorModel)
           #case (model_101)// do that
I want to test for strings, is ttah possible in pov.
thank you
Subject: Re: conditional statements
Date: 17 Jul 2009 05:17:40
Message: <4a6041b4$1@news.povray.org>
"mysdn" <kam### [at] hotmailcom> wrote in message
news:web.4a603abbcc998528ff025eb50@news.povray.org...
> Hi,
> and  in switches
>  #switch(DoorModel)
Yes.
You can test strings in both #if and #case statements, although the syntax
is a little contrived in #case statements.
You can use the 'strcmp' function in #if statements which compares two
strings and returns zero if the two strings are identical. So:
  #if (strcmp(DoorModel, "model_101")=0)
compares a string contained in the variable DoorModel with the literal
scting value "model_101".
In the #case statement the value in the #switch has to be numeric, so you
have to construct something like:
#switch (0)
  #case(strcmp(DoorModel, "model_101"))
  #break
  #case(strcmp(DoorModel, "model_102"))
  #break
  #else
I also often use the 'strlwr' function to desensitize such string
comparisons to upper and lower case.
BTW. You can also use the 'substr' and 'strlen' functions to make it accept
abbreviations of strings during a comparison.
But this can end up with quite long expressions in the #case statement.
Chris B.
Date: 17 Jul 2009 05:50:01
Message: <web.4a6048b86dc58f70a4aed1130@news.povray.org>
In POV 3.6, you can achieve this using:
  #if (strcmp(DoorModel,model_101)) ...
In POV 3.7, POV-Ray's comparison operator works for strings, too, so you can
also use:
  #if (DoorModel = model_101) ...
(Note the single equals sign; POV-Ray does *not* use C/C++ style operators.)
> and  in switches
>   #switch(DoorModel)
No, that's only possible with float values, even in 3.7.
Out of curiosity: Are you sure you want to use strings for the model
identifiers? A numeric id would do, I guess. After all, you can always use
those identifiers you have, like model_101, so you don't have to memorize all
the - possibly cryptic - ids.
If you absolutely need to work with strings for model identifiers, I suggest
translating them to numerical ids first, by looking them up in an array.
Date: 17 Jul 2009 06:15:00
Message: <web.4a604edd6dc58f70a4aed1130@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote:
> #switch (0)
>   #break
>   #break
>   #else
> #end
Ah, now *that's* an interesting idea... thanks, even I still live and learn.
I've always missed an #if ... #elseif construct in POV-Ray, but looks like this
is it.
BTW, in POV-Ray 3.7 it should also work with the comparison operator, i.e.:
  #case(DoorModel = "model_101")
Date: 17 Jul 2009 06:58:51
Message: <4a60596b$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.4a604edd6dc58f70a4aed1130@news.povray.org...
>> #switch (0)
>>   #break
>>   #break
>>   #else
>> #end
> learn.
> this
> is it.
> i.e.:
Well that's good news. That simplifies the syntax. I'll have to give that a
go. It's worth noting that you'd presumably pass '1' or 'true' into the
#switch statement rather than '0' using this new syntax.
Chris B.
Date: 17 Jul 2009 07:29:12
Message: <4a606088@news.povray.org>
  Actually you have to do it like:
#if(strcmp(DoorModel, model_101) = 0) ...
Date: 17 Jul 2009 08:05:00
Message: <web.4a6067d16dc58f70a4aed1130@news.povray.org>
Whoops - yes, of course.
Date: 17 Jul 2009 08:15:01
Message: <web.4a606b2e6dc58f70a4aed1130@news.povray.org>
Yup. Revoco.
Date: 17 Jul 2009 22:25:51
Message: <4a6132af$1@news.povray.org>
> Hi,
> and  in switches
>   #switch(DoorModel)
> thank you
If all your identifiers are of the same format as model_xxx, then, you
can extract the numerical part and test that as a numeric value.
Or
You can construct your identifiers from a "model_" string concatenated
to the numerical part.
In both cases, you'd only need to compare numeric variables, whitch is
much simpler.
