POV-Ray : Newsgroups : povray.newusers : Intersections not quite working? Server Time
28 Sep 2024 18:09:02 EDT (-0400)
  Intersections not quite working? (Message 1 to 6 of 6)
Subject: Intersections not quite working?
Date: 16 Mar 2009 13:45:00
Message: <web.49be8fcd44abb44af8e064a80@news.povray.org>
So, I'm pretty new at this, but I'm trying to render arcs to display the angles
between bonds in molecules, using a function that takes the vectors of the
bonds and uses the intersection of two semicircular prisms to draw an acute arc
- something like this:
#macro drawAcuteArc(centre, arcSweepStart, arcSweepEnd, arcRadius, borderWidth)
  #local arcDepth = 0.1;
  #local arcNorm = vcross(arcSweepStart,arcSweepEnd);
  #local arcAngle = VRotation(arcSweepStart, arcSweepEnd, arcNorm);
  #debug "Angle = "
  #debug str(arcAngle, 0, 3)
  intersection {
    //Semicircle 1
    difference{
      cylinder{ centre - arcDepth * arcNorm, centre + arcDepth * arcNorm,
arcRadius }
      plane{ arcSweepStart, 0 translate centre }
    //Semicircle 2
    difference{
arcRadius }
      plane{ arcSweepEnd, 0 translate centre}
    pigment {rgbf <1,0,0,0>}
drawAcuteArc(0, <0,1,1>, <1,0,0>, 5.5, 0.5)
The only problem is that this doesn't do that. It seems to instead give me a
slice where the arc would start, and a slice where the arc would stop, and no
arc.
If I make the faces more differently placed, it seems to intersect correctly - I
tried making one of the cylinders bigger than the other, and it seemed that only
faces that were created by the intersection, rather than faces which were
coincident in the creating models, were shown. This seems a little dodgy - is
it a bug?
Thanks,
-Ian
Subject: Re: Intersections not quite working?
Date: 16 Mar 2009 15:21:05
Message: <FjpHeyAfaqvJFwF1@econym.demon.co.uk>
>  #debug "Angle = "
>  intersection {
>    //Semicircle 1
>    difference{
>arcRadius }
>    //Semicircle 2
>    difference{
>arcRadius }
>#end
>arc.
>correctly - I
>that only
>it a bug?
Things like that can happen with coincident surfaces.
In the general case, the workround is to displace one of the components
slightly
  #local arcDepth2 = arcDepth*1.00001;
    //Semicircle 2
    difference{
      cylinder{ centre - arcDepth2 * arcNorm, centre + arcDepth2 *
        arcNorm, arcRadius }
However, in this case you don't need a second cylinder. You can just
difference both planes from the same one:
borderWidth)
  difference{
       * arcNorm, arcRadius }
Mike Williams
Gentleman of Leisure
Date: 16 Mar 2009 15:33:05
Message: <NjlFetDvlqvJFwkA@econym.demon.co.uk>
In case you need it at some point, here's the obtuse equivalent:
#macro drawObtuseArc(centre, arcSweepStart, arcSweepEnd, arcRadius,
borderWidth)
  difference{
arcRadius }
    intersection {
      plane{ -arcSweepStart, 0 translate centre }
      plane{ -arcSweepEnd, 0 translate centre}
Mike Williams
Date: 16 Mar 2009 17:03:09
Message: <49BEBE37.5000805@joplin.com>
A few questions about the variable you used:
  'arcSweepStart' & 'arcSweepEnd' are they location vectors or normal
vectors  because you use them as normals in the planes?
The way you use them if they're not pointing in the right direction
it'll get funky.
   'centre' I'm questing would be the midpoint between two atoms.
   'arcRadius' This I'm not sure of. If your connection two atoms at
variable distances from each other, then the radius would have to be
calculated, so that the end points of your bond would touch both atoms.
If in your model the atoms are all equal distance the 'arcRadius' is
redundant
>   #debug "Angle = "
>   intersection {
>     //Semicircle 1
>     difference{
>       cylinder{ centre - arcDepth * arcNorm, centre + arcDepth * arcNorm, arcRadius
>     //Semicircle 2
>     difference{
> arcRadius }
> #end
> arc.
> it a bug?
> Thanks,
> -Ian
Date: 16 Mar 2009 21:00:00
Message: <web.49bef5299813c63bce8107250@news.povray.org>
> slightly
>     //Semicircle 2
>     difference{
> borderWidth)
>   difference{
> #end
Many thanks for this, and for the obtuse form.
My original intention was to use two cylinders so that once I'd got it working,
I'd be able to use the same macro for reflex angles just by calculating the
angle and changing the 'intersection' to a 'merge', which is why the original
looks like it does. I'm now thinking it would be easier to plan to detect the
angle inside an umbrella drawArc function and then use the appropriate macro
from inside.
-Ian
Date: 17 Mar 2009 10:45:00
Message: <web.49bfb6e19813c63bf8e064a80@news.povray.org>
> it'll get funky.
> redundant
This is supposed to draw arcs between molecular bonds, so if you have 3 atoms:
  1
2--3
'centre' is Origin -> 2
'arcSweepStart' and 'arcSweepEnd' are 2->1 and 2->3 (doesn't matter which way
around).
'arcRadius' is there because I didn't want to draw an arc with the edge at 1 or
3, I wanted a smaller one.
I rechecked on your suggestion, and yes, I was mis-using arcSweepStart and
arcSweepEnd - I needed to rotate them about the cross product to get the proper
vectors for the plane.
My almost finished macro looks like this:
#macro drawArc2(centre, arcSweepStart, arcSweepEnd, arcRadius, borderWidth,
invertArc)
  #debug "drawArc: Arc angle = "
  #debug str(arcAngle/(2*pi/360), 0, 3)
  #debug "\n"
  #if( arcAngle = pi )
    //draw180Arc
  #else
    #local planeNormVectorStart = vaxis_rotate(arcSweepStart,arcNorm, 90);
    #local planeNormVectorEnd   = vaxis_rotate(arcSweepEnd,arcNorm, -90);
    difference{
      cylinder{ centre - 2 * arcDepth * arcNorm, centre + 2 * arcDepth *
arcNorm, arcRadius*2 }
      union{
        plane{ planeNormVectorStart, 0 translate centre }
        plane{ planeNormVectorEnd, 0 translate centre }
      #if (invertArc)
        inverse
      pigment {rgbf <1,0,0,0.5>}
It doesn't yet handle 180 degree arcs, but that's just because I haven't decided
how to orient them yet.
And the 'invertArc' variable makes it draw the opposite angle to what it would
without.
Now to polish it off, and test it with Avogadro!
Thanks,
-Ian
