POV-Ray : Newsgroups : povray.newusers : difficulties rendering hexagonal crystal group Server Time
7 Apr 2026 23:24:32 EDT (-0400)
  difficulties rendering hexagonal crystal group (Message 1 to 4 of 4)
Subject: difficulties rendering hexagonal crystal group
Date: 16 Mar 2009 09:35:00
Message: <web.49be542b519610b7604827740@news.povray.org>
in an attempt to explain crystal groups I generated the following:
  location  <0, 0, -270>
  look_at   <0, 0, 0>
  angle 1.7
global_settings {
  assumed_gamma 2.2
  max_trace_level 100
light_source { < 10, 10, -10> color rgb <1.0, 1.0, 0.8> }       // right, top,
front
light_source { <-10, 10, -10> color rgb <1.0, 0.8, 1.0> }       // left, top,
front
light_source { < 10,-10, -10> color rgb <0.8, 1.0, 1.0> }       // right, below,
front
light_source { <-10,-10, -10> color rgb <1.0, 1.0, 1.0> }       // left, below,
front
light_source { <0, 0, -10> color rgb <1.0, 1.0, 0.8> area_light
<10,0,0>,<0,10,0>, 5, 5 }   // center, front
//-------------------------- drawing 3 axes --------------------------------
#macro Axis_( AxisLen, RedTexture,WhiteTexture)
union{
    cylinder {<0,-AxisLen,0>,<0,AxisLen,0>,0.05
              texture{checker texture{RedTexture}
                              texture{WhiteTexture}
                      translate<0.1,0,0.1>}}
    cone{<0,AxisLen,0>,0.2,<0,AxisLen+0.7,0>,0
         texture{RedTexture}}
#macro AxisXYZ( AxisLenX, AxisLenY, AxisLenZ, TexRed, TexWhite)
union{
   object{Axis_(AxisLenX, TexRed, TexWhite)   rotate< 0,0,-90>}   // x axis
   object{Axis_(AxisLenY, TexRed, TexWhite)   rotate< 0,0, 30>}   // y axis
   object{Axis_(AxisLenZ, TexRed, TexWhite)   rotate<-90,0,  0>}   // z axis
   text{ ttf"arial.ttf",  "x",  0.15,  0  texture{TexRed}
         scale 0.5 translate <AxisLenX+0.05,0.4,-0.10>}
   text{ ttf"arial.ttf",  "y",  0.15,  0  texture{TexRed}
         scale 0.5 translate <-2,AxisLenY-1.0,-0.00>}
   text{ ttf"arial.ttf",  "z",  0.15,  0  texture{TexRed}
         scale 0.5 translate <-0.4,0,AxisLenZ-6>}
// ----------------------- object ----------------------------------
#declare  Hexagon =
 intersection
  {plane {z, 1}  /* Rotate 90 in z axis to stand up */
   plane {z, 1 rotate < 60, 0, 0>}
   plane {z, 1 rotate <120, 0, 0>}
   plane {z, 1 rotate <180, 0, 0>}
   plane {z, 1 rotate <240, 0, 0>}
   plane {z, 1 rotate <300, 0, 0>}
   plane { x, 1}
   plane {-x, 1}
   bounded_by {sphere{0, 1.5}}
#declare Hexagonal =
      intersection{
         object{ Hexagon
         object{ Hexagon
                   translate <0, 0.58, 1>
         texture
            { pigment {color rgbf <0.1, 0.15, 0.5, 1.0> }         // blue
              finish { ambient 0.5 diffuse 0.1 phong 0.2 }
         interior
             { refraction on
               ior 1.0
               fade_distance 10
               fade_power 0.2
#declare CutOut =
     difference{
         object{ Hexagon
         object{ Hexagon
                   scale 1.001
         texture
               { pigment {color rgbf <0.2, 0.2, 0.2, 1.0> }         // grey
                 finish { ambient 0.5 diffuse 0.1 phong 0.05 }
         interior
             { refraction on
               ior 1.0
               fade_distance 10
               fade_power 0.2
#declare Final_Object =
    union{
       object{ Hexagonal }
       object{ CutOut }
       rotate <0, 90, 30>
       translate <0, 0, 1>
       scale <1.7, 1.7, -1.0>
union{
   object{AxisXYZ (3,3,3,
                texture{ pigment{rgb<1,0,0>} finish{diffuse 0.8 phong 1}},
                texture{ pigment{rgb<1,1,1>} finish{diffuse 0.8 phong 1}})
   object{ Final_Object
   rotate<20,-20,0>
Both the hexagonal crystal and the cut-out hexagon render fine by themselfs, but
in combination the crystal looses colour, also, the surface of the crystal in
contact with the cut-out becomes invisible. I have fiddled with lighting and
optical properties of the bodies for days, but I just don't get it. Any ideas?
Thanks in advance
Engelbert
Subject: Re: difficulties rendering hexagonal crystal group
Date: 16 Mar 2009 19:19:53
Message: <49bede99$1@news.povray.org>
"engelbert_buxbaum" <eng### [at] hotmailcom> wrote in message
news:web.49be542b519610b7604827740@news.povray.org...
> themselfs, but
> in
> and
> ideas?
You might want to use clipped_by {} instead of difference{}, that way the
faces of the cutout part won't show at all.
And, if you can use it, changing background to white or something other than
black seems to make this show better, likewise no_shadow could help not
confuse the shape.
I tried the following with changed filter colors to transmit colors:
      intersection{
         object{ Hexagon
         object{ Hexagon
         texture
            { pigment {color rgbt <0.1, 0.15, 0.5, 0.7> }         // blue
         interior
             { refraction on
               ior 1.0
               fade_color <0.1, 0.15, 0.5>
               fade_distance 2//10
               fade_power 2//0.2
#declare CutOut =
     //difference{
         object{ Hexagon
              clipped_by{
         object{ Hexagon inverse
                   scale 1.001
         texture
               { pigment {color rgbt <0.2, 0.2, 0.2, 0.7> }         // grey
         interior
             { refraction on
               ior 1.0
               fade_color <0.2, 0.2, 0.2>
               fade_distance 2//10
               fade_power 2//0.2
background {<1,1,1>}
You hadn't given the fade_* a color so I used the ones from pigments, also
making the distance less and power more.
This shows the crystal parts, with color fading, like I think you're trying
to do. Main thing is probably that clipped_by being added (with inverse on
object).
Hopefully that's some help to you. Oh, and not sure from the quick look at
it but I when I moved one of the parts once while checking on it the
position didn't seem to relate to the axis arrows. Maybe just my
perception...
Bob H.
Date: 18 Mar 2009 09:45:00
Message: <web.49c0f9a78bf9de2d604827740@news.povray.org>
> > themselfs, but
> > in
> > and
> > ideas?
> confuse the shape.
Yes, clipping does the trick. A little more phong to the cut-out and the
background reduced to rgb 0.3 and this looks quite decent.
Thanks for the hints
Engelbert
Date: 19 Mar 2009 18:01:31
Message: <49c2c0bb$1@news.povray.org>
I spotted some small errors.
engelbert_buxbaum nous illumina en ce 2009-03-16 09:29 -->
> Hi,
> camera {
>   look_at   <0, 0, 0>
>   angle 1.7
You could use an orthographic camera.
camera{orthographic
	location -100*z
	look_at 0
> global_settings {
>   assumed_gamma 2.2
Phased out. Beter to leave out for future compatibility.
>   max_trace_level 100
> front
> front
> front
> front
Don't realy need that one.
Making adaptive 0 will greatly increase the rendering speed.
> union{
> #end
Most of the time, you want 3 axis of the same length. Maybe you only need to
provide one length.
> union{
> #end
> #declare  Hexagon =
>  intersection
>    plane { x, 1}
>    plane {-x, 1}
A box would provide a tighter bounding shape.
bounded_by{box{<1,1.5,1.5><-1,1.5,1.5>}}
Also, the use of a prism object may be more adventageous.
>       intersection{
>          object{ Hexagon
>          object{ Hexagon
>          texture
That ambient value is very high. It gives a washed out aspect and make you loose
much 3D feeling.
>          interior
>              { refraction on
This is uterly useless, as it's turned off by the next statement.
>                ior 1.0
Any value other than 1 will cause the refraction to be active. A value of 1, as
here, effectively turn refraction OFF.
>                fade_distance 10
>                fade_power 0.2
Without a fade_color, this is pointless.
Also, fade_power of 0.2 is a fade acording to distance power 1/5 (or the fifth
root of the distance) whitch is totaly unrealistic. A value of 1 is physicaly
correct. A value of 1001 is also correct and turn on the "exponential" fading.
The ONLY place where refraction on IS relevant, is in a protons{} block of an
object.
> #declare CutOut =
>      difference{
>          object{ Hexagon
>          object{ Hexagon
>                    scale 1.001
>          texture
>          interior
>              { refraction on
>                ior 1.0
>                fade_distance 10
>                fade_power 0.2
>     union{
>        object{ Hexagonal }
>        object{ CutOut }
>        rotate <0, 90, 30>
>        translate <0, 0, 1>
You have coincident surfaces where the two elements meet. You should move one or
the other a small bit.
> union{
>    rotate<20,-20,0>
> Thanks in advance
> Engelbert
The worst way to miss someone is to be sitting right beside them knowing you
can' t have them.
