POV-Ray : Newsgroups : povray.newusers : Newbie 'difference' question Server Time
19 Nov 2025 03:53:32 EST (-0500)
  Newbie 'difference' question (Message 1 to 7 of 7)
Subject: Newbie 'difference' question
Date: 31 Dec 2008 07:10:01
Message: <web.495b60b84df161259fd2e7280@news.povray.org>
Not sure if this is the right place to ask, but here goes:
I have two objects that each render individually and as a CSG union, but when I
use the CSG difference function on the two objects (both mesh2 objects with
some common and unique volume) neither appears in the render.
Does anyone have some wisdom to impart?
Subject: Re: Newbie 'difference' question
Date: 31 Dec 2008 08:13:28
Message: <cvrml4lpe7oouk0mmjf5f14e6npjggh5vr@4ax.com>
I just did a quick test with two Poser Models and I got the difference and
intersections to render OK. If the meshes are not too big you could post a
scene.
Regards
Date: 31 Dec 2008 09:30:00
Message: <web.495b8159befd7453c67b294d0@news.povray.org>
Make sure that there is an inside vector listed for the mesh and that the mesh
is continuous across the CSG region (no holes).  Either of those two can be
culprits in stealing the CSGed mesh.
-tgq
Date: 1 Jan 2009 06:50:00
Message: <web.495cacb3befd74539fd2e7280@news.povray.org>
> scene.
> Regards
>      Stephen
I had been through and thought I had the objects closed, but I may have that
wrong. Here it is, with excess code culled:
#include "glass.inc"
#include "shapes.inc"
#include "textures.inc"
#include "camera-context.inc"
#declare CamPos = <-.28,0,-.96>;
#declare LightPos = <0,0,-25>;
#declare CamDist = 0.5;
#declare HemiWidth = 0.367;
camera {location CamDist*CamPos look_at -1*CamPos }
sky_sphere{pigment {colour White}}
light_source {LightPos White*3.0 parallel}
#declare Gem = mesh2 {
   vertex_vectors { 5,
        <-HemiWidth,0,-2>, <-HemiWidth,0.722,-1.865>, <HemiWidth,0.367,-1.966>,
<-HemiWidth/3,0.361,-1.932>, 1.15*<-HemiWidth/3,0.361,-1.932>
   texture_list { 1,
      texture{pigment{Col_Glass_Dark_Green}} //pigment{Col_Glass_Dark_Green}}
//0
   face_indices { 6,
 <3,2,1>,0 <0,3,1>,0 <0,2,3>,0 <4,2,1>,0 <0,4,1>,0 <0,2,4>,0
#declare GemFaceAlt = 1.03;
#declare GemFacer = mesh2 {
   vertex_vectors { 6,
        <-HemiWidth,0,-2>*GemFaceAlt, <-HemiWidth,0.722,-1.865>*GemFaceAlt,
<HemiWidth,0.367,-1.966>*GemFaceAlt,
        <-HemiWidth,0,-2>*(0.25+GemFaceAlt),
<-HemiWidth,0.722,-1.865>*(0.25+GemFaceAlt),
<HemiWidth,0.367,-1.966>*(0.25+GemFaceAlt)
   texture_list { 1,    texture{pigment{Col_Glass_Ruby}} //0
   face_indices { 8,    <0,2,1>,0  <0,1,3>,0 <1,2,4>,0 <2,0,5>,0  <0,5,3>,0
<1,3,4>,0 <2,4,5>,0  <3,4,5>,0
//#declare Gemstone = object{Gem} //works
//#declare Gemstone = object{GemFacer} //works
#declare Gemstone = union {object{Gem} object{GemFacer}} //works
//#declare Gemstone = intersection {object{Gem} object{GemFacer}} //renders
blank
//#declare Gemstone = difference {object{Gem} object{GemFacer}} //renders blank
object{Gemstone rotate y*120  translate <2,0,0>}//moves this object into a
close-up position
Date: 1 Jan 2009 08:17:12
Message: <lfgpl4pbgfd909rtkm0sj04q5obthheski@4ax.com>
Sorry Graham, this problem is beyond my ability to help. I get the same problem
as you do. I hope that someone else takes it up.
Regards
Date: 1 Jan 2009 09:04:49
Message: <495ccd81@news.povray.org>
  I really can't believe nobody has answered this completely trivial problem.
  Just add "inside_vector y" to your meshes.
Date: 3 Jan 2009 00:15:01
Message: <web.495ef3f3befd74539fd2e7280@news.povray.org>
Thank you Warp, Stephen, et al.
I've used the "inside_vector y", and I've also replaced the need for some CSG by
doing the math (but that's okay - I like the math).
What I've drawn isn't up to the standard of things on this site, but if you're
interested (and, again, have any comments or suggestions) I've uploaded it to:
http://au.geocities.com/gjdolby/jpgs/ringprog.jpg
and here is the picture I wanted that brought me to POV Ray in the first place:
http://au.geocities.com/gjdolby/jpgs/rwg.jpg
-Graham
