POV-Ray : Newsgroups : povray.newusers : Rendering CAD objects Server Time
28 Sep 2024 20:18:34 EDT (-0400)
  Rendering CAD objects (Message 1 to 4 of 4)
Subject: Rendering CAD objects
Date: 27 Aug 2008 17:55:00
Message: <web.48b5cd08a143ba965d1de84f0@news.povray.org>
I use CAD programs (SW, ProE, Rhino) a lot to design mechanical components. I
would like to be able to render those CAD objects in POV-Ray for more visually
pleasing presentation. Is there an easy way to bring CAD objects into POV-ray?
How would one take a CAD definition and convert it into a renderable script?
Subject: Re: Rendering CAD objects
Date: 28 Aug 2008 02:36:56
Message: <48b64788$1@news.povray.org>
"akash" <sky### [at] hotmailcom> wrote in message
news:web.48b5cd08a143ba965d1de84f0@news.povray.org...
>I
> visually
> POV-ray?
> script?
You're likely to need to do it in two steps.
1. Use whatever export options your CAD softwater has to export the objects
in a format for which there is a POV-Ray converter available (e.g. .obj,
.3ds etc).
2. Use a converter such as PoseRay to convert to POV-Ray mesh or mesh2
objects.
The generated POV-Ray objects can be incorporated into your POV-Ray scene
file either using cut and paste or by '#include'ing the files containing the
objects you've converted.
Chris B.
Date: 29 Aug 2008 00:46:46
Message: <48b77f36$1@news.povray.org>
akash nous illumina en ce 2008-08-27 17:54 -->
Export your models to an intermediate file, such as .DXF. Most CAD programms can
export to that format.
Import then into PoseRay.
 From PoseRay, export to POV (.pov or .inc)
Render in POV-Ray.
Impressionism: From a distance, shit looks like a garden.
Date: 11 Sep 2008 09:53:10
Message: <48c922c6@news.povray.org>
> components. I would like to be able to render those CAD objects in POV-Ray
> for more visually pleasing presentation. Is there an easy way to bring CAD
> objects into POV-ray? How would one take a CAD definition and convert it
Rhino has a POV export option built in. You can choose to export the entire
project as one large file or with each object as its own include file. You
can also use a slider to choose how fine the polygon mesh is. It works
quite well.
