POV-Ray : Newsgroups : povray.newusers : creating calabi-yau manifolds Server Time
16 Aug 2025 11:54:09 EDT (-0400)
  creating calabi-yau manifolds (Message 1 to 3 of 3)
Subject: creating calabi-yau manifolds
Date: 21 Aug 2008 05:55:01
Message: <web.48ad3b17bd3c71ece62335cd0@news.povray.org>
I would like to use POVRay to create (hopefully pleasing) images of calabi-yau
manifolds, like http://en.wikipedia.org/wiki/Calabi-Yau_manifold.
I'm a complete newbie, so any pointers to .pov files or tuts would be most
appreciated.
Thanks in advance and best regards,
Maurice
Subject: Re: creating calabi-yau manifolds
Date: 21 Aug 2008 08:47:56
Message: <8l4ELSBKLWrIFwGd@econym.demon.co.uk>
>appreciated.
POVRay doesn't solve 6-dimensional polynomials of complex variables, so
you'll need to find a way to express a 3-dimensional cross section of
the manifold using only expressions that are available in POVRay.
If you end up with something that can be expressed as a polynomial of x,
y and z, then you can use the poly object.
        F(x,y,z) = 0
where F is a function that uses only trig functions, hyperbolic trig
functions, logs, powers and simple arithmetic on real variables, then
you can use an isosurface.
        x = Fx(u,v)
        y = Fy(u,v)
        z = Fy(u,v)
Then you can use a parametric object. Parametric objects can be
extremely slow, but you can use Ingo Janssen's Param.inc to approximate
them with smooth meshes.
Mike Williams
Gentleman of Leisure
Date: 21 Aug 2008 17:00:00
Message: <web.48add6224a9a9f045afe6fd0@news.povray.org>
> >appreciated.
>         F(x,y,z) = 0
>         x = Fx(u,v)
>         y = Fy(u,v)
>         z = Fy(u,v)
> Mike Williams
Thank you for taking the time to reply so promptly, I'm very grateful.
I'll explore what you suggested and see if a solution is possible.
Best regards,
Maurice
