POV-Ray : Newsgroups : povray.newusers : #declare inside a loop - name depending on counter? Server Time
13 Mar 2026 22:13:17 EDT (-0400)
  #declare inside a loop - name depending on counter? (Message 1 to 4 of 4)
Subject: #declare inside a loop - name depending on counter?
Date: 9 Jun 2008 05:10:00
Message: <web.484cf2d470f619f3f495ce020@news.povray.org>
How can I declare a variable inside a loop while the name which I declare
depends on a counter?
I'd like to generate 100 clock variables (clockX1 to clockX100). To do this, I
hoped to use something like
#declare concat("clockX",str(SomeCounter))=...
How can I tell POVRay to use the actual value of a variable/function instead of
the variable name?
In other words not to assign
 #declare Mystring=...
but to declare a new variable named by the value of Mystring.
I guess it's a simple thing (like using the $variable in IGOR) but I couldn't
find it in the help/support.
Subject: Re: #declare inside a loop - name depending on counter?
Date: 9 Jun 2008 07:07:03
Message: <484d0ed7$1@news.povray.org>
"Tungsten" <nomail@nomail> wrote in message
news:web.484cf2d470f619f3f495ce020@news.povray.org...
> this, I
> instead of
> the variable name?
> couldn't
Sounds to me like you would be better off using arrays:
#declare ClockX = array[100];
#declare SomeCounter = 0;
#while (SomeCounter <100)
  #declare ClockX[SomeCounter] = ...  ;
  #declare SomeCounter = SomeCounter + 1;
The only way that I know of doing precisely what you asked for is to create
a string using the concat function that you write out to a file, then
#include the file on the following line so that it gets parsed. I think
there is a function somewhere to do this for you, but it obviously
introduces additional disk IO that can slow your render down.
Chris B.
Date: 9 Jun 2008 09:45:00
Message: <web.484d33c5458e1efff495ce020@news.povray.org>
> #end
That's the way, it works perfectly.
Thank you very much for the quick and clear reply!
Date: 10 Jun 2008 09:07:14
Message: <484e7c82$1@news.povray.org>
> #end
The Parse_String macro in strings.inc does this for you.  However, I
would agree with you that I don't see a good reason to use this instead
of arrays in this circumstance.
-The Mildly Infamous Blue Herring
