POV-Ray : Newsgroups : povray.newusers : Image maps and heightfields Server Time
16 Aug 2025 21:14:54 EDT (-0400)
  Image maps and heightfields (Message 1 to 3 of 3)
Subject: Image maps and heightfields
Date: 21 Mar 2008 19:45:01
Message: <web.47e4547bb02d5773bebf2c990@news.povray.org>
I have an unusual problem -- image maps that are a different size and aspect
ratio than the heightfield they match.
I have precise information on where they belong relative to the heightfield, and
I can get them to fit with hardcoded values, but any sort of macro to fit it
based on the information I have has eluded me for the last week.
Hence I politely ask for help creating a macro for the translations+rotations in
the pigment section, like:
IMG_FIT(-0.5, +0.0,
        +1.0, +1.0)
where the first two coordinates are the upper left corner of the imagemap
relative to the heightfield, and the second two are the lower right.  Yes, part
of the left side of the image would miss the heightfield, that is the idea.
My silly efforts so far, just so you know I've tried:
#macro IMGMAP_FIT(XSCALE, YSCALE, XOFF, YOFF)
        rotate <90, 0, 0>           // Face up
        translate<-0.5, -0.5, -0.5> // Center
        scale <-XSCALE, 1, -YSCALE> // Resize
        translate<(XSCALE-1)/2, 0, -(YSCALE-1)/2> // Relocate
Subject: Re: Image maps and heightfields
Date: 21 Mar 2008 23:07:04
Message: <47e485e8$1@news.povray.org>
Corona688 nous apporta ses lumieres en ce 2008/03/21 20:43:
> IMG_FIT(-0.5, +0.0,
>         +1.0, +1.0)
The first two parameters are scaling factors.
The last two are *suposed* to be placement parameters, but not used.
> #end
If you rewrite your macro with the provided values, you get:
rotate 90*x
translate -0.5
scale <-(-0.5),1,-0>// become: scale<0.5,1,1>
translate<(-0.5-1)/2,0,-(0-1)/2>//become: translate<-0.75,0,0.5>
The net translation is: <-1.25,-0.5,0>
You want to scale the image relative to it's center. Use:
translate -0.5 //center around origin
scale<XSCALE,1,YSCALE> //scale it
translate 0.5 // return it to it's original position
Now, you want to place if acording to your offset
translate<XOFF,1,YOFF>
Adult, n.: One old enough to know better.
Date: 23 Mar 2008 11:30:01
Message: <web.47e684ae5496961e0c220080@news.povray.org>
> Alain
Thank you so much, your help was key!  I have finally realized my goal of
placing images on heightfields algorithmically by their global coordinates
alone.
On the off chance anyone else is struggling to match Canadian Toporama imagery
to Canadian Geobase DEM data:
        translate <-0.5, -0.5, -0.5>    // Center on origin
        scale<XSCALE, 1, YSCALE>        // Scale
        translate<0.5, 0.5, 0.5>        // Move off origin
        translate<(XSCALE-1)/2, 0, -(YSCALE-1)/2>       // Position upper-left
        translate<-XOFF, 0, YOFF>       // Translate
#macro DEM_FIT(DEMLAT, DEMLON, DEMH, DEMW,
        IMGLAT, IMGLON, IMGH, IMGW)
        IMGMAP_FIT(     IMGW/DEMW,              IMGH/DEMH,
                        (DEMLON-IMGLON)/DEMH,
                        (DEMLAT-IMGLAT)/DEMW)
height_field
        tga "062L10w.tga"
        water_level 0
        /* Match the orientation of the map to screen coordinates */
                rotate <0, -90, 0>
        translate<+0.5, +0.5, +0.5>
        pigment
                image_map       {       gif "062L10.gif" once   }
                // Toporama gives different aspects for different latitudes
                // of map!  A general image-fitter makes it so much tidier.
                DEM_FIT(182700, -370800, 900, 900,
                        182700, -370800, 900, 1800)
Also note that ye olde dem2pov.c fails for Geobase DEM data, since
smaller-than-one spatial resolutions round to ZERO.  I'll find somewhere to
post fixes once I have something better than my current hack.
