POV-Ray : Newsgroups : povray.newusers : to make group in the mesh Server Time
14 Mar 2026 00:11:51 EDT (-0400)
  to make group in the mesh (Message 1 to 4 of 4)
Subject: to make group in the mesh
Date: 12 Feb 2008 05:25:00
Message: <web.47b1738e5f9a6c867b1612e30@news.povray.org>
Hi everybody!
I have this face scene,where I have to define different region based on the
location on the face(Such as one region for nose other for lips..and so on) but
the problem I am facing is that even though I know the coordinate for all the
triangle in the scene file i don't know which one corresponds to which region
and I can't do this randomly since scene file has 15000 triangles.
I would appreciate if you guys could help me out here.
Thanks
Subject: Re: to make group in the mesh
Date: 12 Feb 2008 07:21:19
Message: <47b18f3f@news.povray.org>
"here_I_am" <nomail@nomail> wrote in message
news:web.47b1738e5f9a6c867b1612e30@news.povray.org...
> Hi everybody!
> the
> on) but
> the
> region
> Thanks
The best approach depends on what you need to do with the different regions.
I suspect that the most effective approach overall would be to use a
modeller (either the one you created the mesh in or another modeller that
can read the mesh) and split the object down into separate meshes for each
of the 'regions' you need to manipulate independently.
Failing that, you can use CSG with meshes (so long as the mesh normals are
all ok). You may therefore be able to use objects to carve areas out of the
face and split it up in that way. For example, you could define a simple
squashed sphere and position it (using trial and error) to engulf just the
nose. You could then use a sphere with the same values in a CSG intersection
with the mesh to isolate the nose and manipulate it independently of the
rest of the face.
If you only need to identify separate regions for texturing it is possible
to use CSG within an  'object' pigment, so you could define a texture that
corresponds to the regions that you identified by trial and error.
If you only need to find points on the surface of the face (e.g. for
positioning eyelashes, glasses, a pipe or a hat) you could use the 'trace'
function. Once again this can be done fairly quickly with a little bit of
trial and error. Use 'trace' to locate a point on the surface somewhere near
where you want to be. Add a little sphere or a thin cylinder to your test
render and refine the trace parameters to home in on the points you need -
e.g. the bridge of the nose, the corners of the lips etc.
Also, if you have development skills you could use your favourite computer
language to split the mesh up using mathematical rules that you could devise
based on the trial and error technique above.
If you can give a bit more of an indication of what you need to do it'll
probably be possible to recommend a particular approach.
Chris B.
Date: 12 Feb 2008 12:44:51
Message: <47b1db13$1@news.povray.org>
Chris B nous apporta ses lumieres en ce 2008/02/12 07:21:
>> Hi everybody!
>> the
>> on) but
>> the
>> region
>> Thanks
> rest of the face.
> Regards,
> Chris B.
If you use CSG to cut a mesh, you don't need the mesh normals to be correct, or
even the mesh to be closed.
You need a well behaved mesh if you use it to cut another object.
If you are good, you will be assigned all the work. If you are really good, you
will get out of it.
Date: 17 Feb 2008 06:25:00
Message: <web.47b81963a507e67ab61821680@news.povray.org>
> >> Hi everybody!
> >> the
> >> on) but
> >> the
> >> region
> >> Thanks
> > rest of the face.
> > Regards,
> > Chris B.
> Alain
> will get out of it.
Thanks Chris and Alain for the suggestion.
As Chris suggested I tried using Maya to Chop my scene into different region.I
succeed but it turns out that when I tried to render those scene(regions) in
pov-ray..they had different orientation and spatial coordinate.Thus that rules
out the idea of chopping in Maya.
To make this work I am using CSG, means hit and trial and am finding the
intersection of face and cylinders and by using different cylinders  I'll have
different groups. I guess this is what you guys suggested me.
Basically I have different albedo map based on the location on the face and have
to use Torrance-sparrow BRDF model and since different region have different
BRDF coefficient.I need to chop my scene in to different region.
I would appreciate if you add something to it.(Other than what I am doing to
make this grouping thing more efficient)
Thanx
Regards
Ran.
