POV-Ray : Newsgroups : povray.newusers : Merging Isosurfaces Server Time
12 May 2026 07:04:13 EDT (-0400)
  Merging Isosurfaces (Message 1 to 3 of 3)
Subject: Merging Isosurfaces
Date: 28 Jan 2008 10:20:01
Message: <web.479df26828aaf275cc12f9390@news.povray.org>
I wonder if anyone can help me, I'm trying to create an isosurface which from
above will be shaped as a T. My first idea was to do a rectangle and then cut
off the bits I didn't want with a difference{} but this still calculates the
whole isosurface which seems inefficient. My next plan was to have 2 isosurface
with the same function to create the T shape. The problem is, I need the
isosurface to reflect/refract and allow light to pass through it. My
understanding is that instead of union{}ing the 2 isosurfaces, I simply needed
to merge{} them - but unfortunately, thsi leaves strange artifacts visible
(vertical black lines) I've tried overlapping the 2 isosurfaces in case it was
due to a rounding error on the boundary to no effect. I've increased max_trace
by an order of magnitude which hasn't helped either.
Can someone please point me in the right direction?
Thanks in advance,
Basiclife
Subject: Re: Merging Isosurfaces
Date: 28 Jan 2008 11:46:22
Message: <EzwqOgCYPgnHFw8H@econym.demon.co.uk>
Wasn't it Basiclife who wrote:
>Hi,
One possible approach is to produce a single isosurface that has the
required shape
global_settings { max_trace_level 10 }
#declare Box = function { max((y*y-1),(x*x-1),(z*z-1)) }
isosurface {
  function {  min(
                Box(x,y*4-4,z*4),
                Box(x*4,y,z*4)
           max_gradient 45
           contained_by{sphere{0,2}}
           pigment {rgbt .9}
           interior {ior 1.3}
See: http://www.econym.demon.co.uk/isotut/combine.htm
Mike Williams
Gentleman of Leisure
Date: 28 Jan 2008 16:14:47
Message: <479e45c7$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:Ezw### [at] econymdemoncouk...
>>Hi,
>>from
>>cut
>>the
>>isosurface
>>needed
>>was
>>max_trace
> required shape
> isosurface {
>  function {  min(
>                Box(x,y*4-4,z*4),
>                Box(x*4,y,z*4)
>           max_gradient 45
>           pigment {rgbt .9}
>           interior {ior 1.3}
> Mike Williams
Many thanks for the response,
that seems like exactly what I need to do. I'm going to try and do as you
suggesed with my formulae and hopefully it should all work. If I have any
issues, I may need to come back and ask some more questions
Many thanks
Basiclife
