POV-Ray : Newsgroups : povray.newusers : Sponge Server Time
5 Apr 2026 18:12:47 EDT (-0400)
  Sponge (Message 11 to 12 of 12)
Subject: Re: Sponge
Date: 24 Dec 2007 10:05:00
Message: <web.476fc9ded68f7f9fc150d4c10@news.povray.org>
Your best bet is the crackle pattern.  Try the following function:
//START
#declare PP=
function{pattern{
  crackle
  form <-1.5,0.9,0.3>
    scale 1/10
    warp{
      turbulence 0.2
    scale 1/10
    warp{
      turbulence 0.1
    scale 100
    scale 1/20
    scale <1,0.75,1>
isosurface {
  function {PP(x,y,z)}
  contained_by { box { -1.2, 1.2 } }
  threshold 0.1
  accuracy 0.001
  evaluate 100,1.5,0.7
  pigment{rgb <1,0,0>}
  scale 1/2
//END
You can twickle the values a bit.  The form values tend to be very sensitive.
Also play with threshold and the warps (feel free to add more or less warps if
required.  As it can render quite slow, try using it as a pigment first to get
a quick feel for the overall look before running the isosurface.
-tgq
Subject: Re: Sponge
Date: 24 Dec 2007 18:35:00
Message: <web.477040abd68f7f9f9c37dbc40@news.povray.org>
If you're interested about my second method of making a sponge, here it is:
#declare S=seed(0);
light_source
   <3,5,10>
   rgb 2
camera
   location <3,5,10>
   look_at 0
   angle 30
#declare bubtotal=1000;
#declare bubsize=function(bub){exp(bub/bubtotal)/10}  //bubsize is radius
#declare bubble=0;
#declare bubpos=array[bubtotal]
#declare bubgrid=array[bubtotal][bubtotal]
#while(bubble<bubtotal)
   #declare xarea=(1+2*bubsize(bubble))*(4+2*bubsize(bubble));
   #declare yarea=(2)*(4+2*bubsize(bubble));
   #declare zarea=2;
   #switch(rand(S)*(xarea+yarea+zarea))
      #range(0,xarea)
         #declare
bubpos[bubble]=<1+(2*rand(S)-1)*bubsize(bubble),(2*rand(S)-1)*(.5+bubsize(bubble)),(2*rand(S)-1)*(2+bubsize(bubble))>;
      #break
      #range(xarea,xarea+yarea)
         #declare
bubpos[bubble]=<(2*rand(S)-1)*1-bubsize(bubble),.5+(2*rand(S)-1)*bubsize(bubble),(2*rand(S)-1)*(2+bubsize(bubble))>;
      #break
      #range(xarea+yarea,xarea+yarea+zarea)
         #declare
bubpos[bubble]=<(2*rand(S)-1)*1-bubsize(bubble),(2*rand(S)-1)*.5-bubsize(bubble),2+(2*rand(S)-1)*bubsize(bubble)>;
      #break
   #declare bubble=bubble+1;
union{
#declare bubble=0;
   sphere{bubpos[bubble],bubsize(bubble)
   #declare bubble2=bubble+1;
   #while(bubble2<bubtotal)
#if(vlength(bubpos[bubble]-bubpos[bubble2])<bubsize(bubble)+bubsize(bubble2))
         clipped_by{sphere{bubpos[bubble2],bubsize(bubble2) inverse}}
      #declare bubble2=bubble2+1;
pigment{color rgb <1,.9,.2>}
clipped_by{box{<1,.5,2>,-<1,.5,2>}}
If you're going to make something based on taking spheres out of a box, I'd
recommend using a modified version of this, as on of the things I did to speed
up render time was to make it only draw spheres along the surface. By the way,
despite the speeding up thing there are tens of millions of tokens, so don't
think it doesn't work.
I think I got it to work with the crackle pattern. How's this one?
light_source
   <3,5,10>
   rgb 2
camera
   location <3,5,10>
   look_at 0
   angle 30
#declare F=function{pigment{
  crackle
  turbulence 0
  color_map { [0 rgb .2] [1 rgb 0] }
  scale 0.02
intersection{
   isosurface
      #declare asdf = 25;
function{max(f_noise3d(asdf*x,asdf*y,asdf*z),f_noise3d(asdf*(x+1),asdf*y,asdf*z),f_noise3d(asdf*(x+4)/2,asdf*y/2,asdf*z
/2))-.7}
      contained_by{box{<1,.5,2>*1.00001,-<1,.5,2>*1.00001}}
      max_gradient 4.631
   box{
      <1,.5,2>,-<1,.5,2>
      texture{
         pigment{color rgb <1,1,.5>}
         normal{function{F(x,y,z).red}}
   pigment{color rgb <1,1,.5>}}
