POV-Ray : Newsgroups : povray.newusers : shapes and colors Server Time
18 Dec 2025 05:45:55 EST (-0500)
  shapes and colors (Message 1 to 8 of 8)
Subject: shapes and colors
Date: 30 Nov 2007 02:15:00
Message: <web.474fb83b21492ecb4ac3566b0@news.povray.org>
Is there a way to fill a shape with one color and give the shape's outer line a
different color?
ex: I need to have a blue color box with its lines(which show the edges of the
shape surfaces) in red color.
Subject: Re: shapes and colors
Date: 30 Nov 2007 03:42:46
Message: <474fcd06$1@news.povray.org>
> line a
> different color?
> the
You can get by with using the object pattern to color the
edges differently.
Or you can do this with find-edges as a post-process with
a paint program for more complicated scenes.
#include "shapes.inc"
#macro outlined_box(a b os c1 c2)
   box{a,b pigment{object{Wire_Box_Union(a-os,b+os,os) c1 c2}}}
union {
   outlined_box(<-0.5,-0.5,-0.5>,<0.5,0.5,0.5>,0.1,Red,Green)
   rotate 45*y
   rotate 45*x
Date: 1 Dec 2007 15:50:00
Message: <web.4751c82ae3788ac5278fa6d50@news.povray.org>
> different color?
You mean an outline or a wireframe?
A wireframe is best made using cylinders. The clever way is to defign the
cylinder thickness as:
Thickness*VDist(CameraLocation, ObjectLocation)/image_height
Thickness should be replaced with your radius value in pixels. Note that
"image_height" is a built-in Pov-Ray function (don't replace it with a number).
This is obviusly not fool-proof. Using cones (individually calculated ends
radius) would fix most problems asociated with closeups and wide angle cameras.
If you want an outline in Pov-Ray then it's simply not humanly possible and you
better go with the image processor option as stated above. The clever way to do
that is to make a copy of the original scene and modify it so all outlined
object(s) are presented as white with ambient 1 diffuse 0 and everything not
outlined as black. Use RGB component colors instead of white to support
overlapping objects (so you don't have to play around with multiple files, just
copy from the channels).
Hint: in my book "not humanly possible" includes a scheme to use object pattern
with a rotated box and transparency presented on a polygon square. Which
probably won't work in practic either :(
If edge detect doesn't play nice then you may want to try blur and levels then
eliminate the "bleeding in" by re-introducing the original as a screen layer
(aka "additive").
Date: 2 Dec 2007 22:43:26
Message: <47537B18.6040906@joplin.com>
> different color?
The others have give you good advice. But, how about a simple way.
box{-1,1 pigment{boxed color_map{[.1 Red][.1 Blue]}scale 1.01}}
  or have I missed the boat?
Date: 2 Dec 2007 23:06:21
Message: <475380bd$1@news.povray.org>
Your example is red on the whole surface of the box.
Other sized boxes will have at most two sides that
have a blue field with red outline using that pigment.
Date: 3 Dec 2007 09:22:54
Message: <4754113e$1@news.povray.org>
Leroy nous apporta ses lumieres en ce 2007/12/02 22:42:
>> outer line a
>> different color?
>> edges of the
It will only work for an almost square superellipsoid, and the lines will be
rounded.
In the case of a box, all faces are at the same distance from the reference
planes, and the boxed pattern behave the same. The result: all the faces receive
a constant plain colour.
You know you've been raytracing too long when you have ever said "I don't need
no steenking modellers!!!"
Stephan Ahonen
Date: 3 Dec 2007 23:34:27
Message: <4754D88B.20308@joplin.com>
Your both right, I wasn't thinking! :( I didn't even test it.
I'd been using the box pattern of a two dimension surface.
It don't expand to 3d object that easily.
Leroy wrote:
>> outer line a
>> different color?
>> edges of the
Date: 4 Dec 2007 00:00:19
Message: <4754DE9C.30403@joplin.com>
> I'd been using the box pattern on a two dimension surface.
Try this I didn't write it I want to say Warp did but can't be sure
#declare Pig=pigment{boxed color_map{[.1 Red][.1 Blue]}scale<.9,.9,1.5>}
#declare Pyramid = function { abs(x) < y & abs(z) < y };
#declare CubePattern =
   function
   { Pyramid(x, -z, y)*1/6+
     Pyramid(y, x, z)*2/6+
     Pyramid(x, z, y)*3/6+
     Pyramid(y, -x, z)*4/6+
     Pyramid(x, -y, z)*5/6
#declare ThePigment =
   pigment
   { function { CubePattern(x, y, z) }
     pigment_map
     { [0/6 Pig rotate x*90] //top
       [1/6 Pig]              //front
       [2/6 Pig rotate -y*90]//left
       [3/6 Pig rotate -y*180]//back
       [4/6 Pig rotate y*90] //right
       [5/6 Pig rotate -x*90] //bottom
box{-1,1 pigment{ThePigment}}
You could replace the pigment statment with 6 different image_map
pigments if ya like.
Have fun!
