POV-Ray : Newsgroups : povray.newusers : Including my own objects Server Time
29 Sep 2024 00:19:23 EDT (-0400)
  Including my own objects (Message 1 to 3 of 3)
Subject: Including my own objects
Date: 9 Nov 2007 14:55:00
Message: <web.4734b9ff9f5599fc15272f4f0@news.povray.org>
If i rendered some objects using anim8tor and then converted them to a povray
file using ani2pov, how would i include my own objects in a scene?
Subject: Re: Including my own objects
Date: 10 Nov 2007 01:18:32
Message: <47354d38@news.povray.org>
lafferjm napsal(a):
try using
#include "myObj.pov"
If that doesn't make any difference itself then you can just use
object{myObj ...} .
If that does display the object (I don't expect that) you use
#declare myObj=
union{ //just in case
Date: 11 Nov 2007 23:15:01
Message: <web.4737d240de206e2d3b1f88e0@news.povray.org>
Another way to get an Anim8or object into POVRay is to export the object as
either .3ds or .obj and import it into PoseRay.  PoseRay outputs four (4) files
into POVRay, three (3) include files and one scene file.  I save all of them in
As an example, if you export an object from Anim8or as either MyObject.3ds or
MyObject.obj, and import them into PoseRay, that program will export the
following files to POVRay:  MyObject_POV.main_inc, MyObject_POV_geom.inc.,
MyObject.mat.inc., and MyObject_POV_scene.pov.
The name of the object will be listed in the scene file.  The geom.inc files
contains the mesh description of the object, and includes the mat.inc file,
like.
Anim8or.  That is the orientation used in PoseRay.
modeller, and PoseRay is a real gift to the POVRay community.
