POV-Ray : Newsgroups : povray.newusers : Prisms and Laser Beams in a dusty media Server Time
14 Mar 2026 00:11:50 EDT (-0400)
  Prisms and Laser Beams in a dusty media (Message 1 to 4 of 4)
Subject: Prisms and Laser Beams in a dusty media
Date: 4 Nov 2007 15:25:00
Message: <web.472e2a95e649ea69e361d01d0@news.povray.org>
Hi
tried to generate a 'white laser beam' through a prism (black sourrounding,
windows xp) watching for the dispersion (Factor 1.5, samples 15). The laser
beam should be visible by scattering in a dusty air media. Unfortunately the
laser beam generated by a spot light is only visible before hitting the prism
surface but not visible after passing the prism. Any ideas why this happens? I
have only one air media specified with IOR=1, scattering on, mie hazy,
extinction 0.1, scattering color grey 0.86 lum.
The beam should be light enough to show at least some scattering. Any ideas what
to improve?
Thanks MRe
Subject: Re: Prisms and Laser Beams in a dusty media
Date: 4 Nov 2007 16:09:05
Message: <472e34f1$1@news.povray.org>
MRe napsal(a):
> Hi
> to improve?
> Thanks MRe
see photons in the documentation.
Date: 5 Nov 2007 01:46:22
Message: <472ebc3e@news.povray.org>
MRe napsal(a):
> Hi
> to improve?
> Thanks MRe
Another thing to tryb is to use object media (as tight as possible)
instead of global media whenever possible. This improves the quality a
lot. But that's not necessary in your case
Date: 5 Nov 2007 09:38:24
Message: <472f2ae0$1@news.povray.org>
MRe nous apporta ses lumieres en ce 2007/11/04 15:24:
> Hi
> to improve?
> Thanks MRe
You need to enable photons. Search for photons in the documentation.
You need to set the prism as target and turn on refraction.
You don't need to add anything to your light.
A dispersion of 1.5 is prety strong, a realistic value should be more in the
1.01 to 1.1 range. You don't need to set the ior for the "air".
I believe that banking institutions are more dangerous to our liberties than
standing armies. Already they have raised up a monied aristocracy that has
set the government at defiance. The issuing power should be taken from the
banks and restored to the people to whom it properly belongs.
Thomas Jefferson
