POV-Ray : Newsgroups : povray.newusers : anti-aliasing with povray(unix/linux) Server Time
17 Aug 2025 05:58:55 EDT (-0400)
  anti-aliasing with povray(unix/linux) (Message 1 to 8 of 8)
Subject: anti-aliasing with povray(unix/linux)
Date: 14 Sep 2007 10:55:00
Message: <web.46ea9fdab213ab017c492ce20@news.povray.org>
   I'm trying to figure out how use anti-aliasing with povray on linux and I
can't find any documentation on this.  I don't know if this is standard, but
I use a shell to render images.  So my command line is:
povray file_name.pov +W1280 +H960
To use anti_aliasing how would I modify this command, and specify a
threshold and all that?
 Thanks,
        Sebastian
Subject: Re: anti-aliasing with povray(unix/linux)
Date: 14 Sep 2007 11:29:37
Message: <46eaa8e1$1@news.povray.org>
Sebastian wrote:
> Hi,
<http://www.povray.org/documentation/view/3.6.1/216/>
	Thorsten
Date: 14 Sep 2007 11:36:45
Message: <46eaaa8d@news.povray.org>
This is perfectly standard, and the command line options are described
in the documentation in section 2.1.2:
http://www.povray.org/documentation/view/3.6.1/215/
Specifically, for antialiasing the documentation is here:
http://www.povray.org/documentation/view/3.6.1/223/#s02_01_02_08_04
so your command line should look like:
povray file_name.pov +W1280 +H960 +A0.3
if you want a threshold of 0.3, for example...
Maybe it would be more convenient for you to put everything in an INI
file if there are settings you use frequently.
Hope this helps,
Vincent
Date: 14 Sep 2007 11:46:45
Message: <46eaace5@news.povray.org>
Besides what has been told, here are some useful combinations I use a lot:
+a : Basic default antialiasing (threshold 0.3, method 1).
+a +am2 : Basic antialising using method 2
+a0.1 : More accurate antialiasing, method 1
+a0.1 +am2 : More accurate antialiasing, method 2
Date: 14 Sep 2007 11:50:00
Message: <web.46eaad5951572fd27c492ce20@news.povray.org>
Thanks, but I dont see anything on anti-aliasing on that or the following
pages.  Am I missing it somewhere?
Date: 14 Sep 2007 11:55:00
Message: <web.46eaae8151572fd27c492ce20@news.povray.org>
Got it - thanks guys
   Sebastian
Date: 14 Sep 2007 12:07:10
Message: <46eab1ae@news.povray.org>
Ups, sorry, copy and paste error:
<http://www.povray.org/documentation/view/3.6.1/223/>
	Thorsten
Date: 14 Sep 2007 15:00:01
Message: <web.46eada2c51572fd2773c9a3e0@news.povray.org>
command line options as warp put it are good, but I believe the best povray
antialiasing comes with "camera { focal_point fp blur_samples n aperture a
play with these camera settings and you'll come up with some astounding
images.  You don't need it to be all too blurry...
