POV-Ray : Newsgroups : povray.newusers : image brightness Server Time
18 Dec 2025 16:23:49 EST (-0500)
  image brightness (Message 1 to 2 of 2)
Subject: image brightness
Date: 14 Sep 2007 09:10:00
Message: <web.46ea870cd87267e0a9ce4df50@news.povray.org>
Hello,
 how do I make an image_map (or even any pigment) brighter or darker?
I could average it with black but that is not that nice and it can only
darken the picture (unless you can use negative weights).
 Also, how do I create a pigment which is a sum of red gradient x, green
gradient y and blue gradient z, so that the pigment color describes its
position in space?
the best I could do is to average those three gradients but I look for a
cleaner way.
 Thanks in advance,
Honnza
Subject: Re: image brightness
Date: 14 Sep 2007 09:33:05
Message: <46ea8d91$1@news.povray.org>
> position in space?
> cleaner way.
I don't know if it's the cleanest way but this seems to do the trick:
#declare colorCube =  pigment
   gradient x
   pigment_map
    [0 gradient y
       pigment_map
        [0 gradient z color_map{[0 rgb <0,0,0>][1 rgb <0,0,1>]}]
        [1 gradient z color_map{[0 rgb <0,1,0>][1 rgb <0,1,1>]}]
    [1 gradient y
       pigment_map
        [0 gradient z color_map{[0 rgb <1,0,0>][1 rgb <1,0,1>]}]
        [1 gradient z color_map{[0 rgb <1,1,0>][1 rgb <1,1,1>]}]
A bit repetitive, but...
Vincent
