POV-Ray : Newsgroups : povray.newusers : help Error? Server Time
29 Sep 2024 02:20:16 EDT (-0400)
  help Error? (Message 1 to 6 of 6)
Subject: help Error?
Date: 8 Aug 2007 05:05:01
Message: <web.46b986e59ab1292ad7b596fc0@news.povray.org>
I'm new at Povray.
I use the following code in order to find intersection of 30 planes and 19
quadratics, plane normals and points are given in 2-dimensional array p and
q, coefficients of quadratics given in 2-dimensional array qq.
But I got the following error message: in qq[j]: "array subscript out of
range"
Maybe it is trivial but I didn't understand why? Can somebody help me?
  #declare i=0;
  #declare j=0;
  #while (i<31)
  intersection{
  plane
{<p[i][0],p[i][1],p[i][2]>,p[i][0]*q[i][0]+p[i][1]*q[i][1]+p[i][2]*q[i][2]
  quadric
<qq[j][2],qq[j][4],qq[j][6]>,<qq[j][7],qq[j][8],qq[j][9]>,<qq[j][1],qq[j][3],qq[j][5]>,qq[j][0]
  #declare i=i+1;
    #if (j<20)
      #declare j=j+1;
Subject: Re: help Error?
Date: 8 Aug 2007 06:03:51
Message: <46b99507$1@news.povray.org>
Katherina nous apporta ses lumieres en ce 2007/08/08 05:03:
> I'm new at Povray.
> range"
>   #declare i=0;
>   #declare j=0;
>   #while (i<31)
>   intersection{
>   plane
>   quadric
>   #declare i=i+1;
>     #if (j<20)
>       #declare j=j+1;
>   #end
>   #end
After the last time your test on "j" succeede, j = 20. Your array's last element
is 19, you want to access element 20 whitch don't exist.
Solution:
Use 2 successive #while loops. The first one been only for the planes, the
second only for the quadrics.
The order of the elements of the intersection have no impact: All components
after the first are intersected from the first one.
You know you've been raytracing too long when you were ever dragged out of a
theater for yelling "Cheap rasterized graphics!!!" in the middle of Toy Story.
Stephan Ahonen
Date: 8 Aug 2007 06:50:01
Message: <web.46b99ef42d937f37d7b596fc0@news.povray.org>
> > I'm new at Povray.
> > range"
> >   #declare i=0;
> >   #declare j=0;
> >   #while (i<31)
> >   intersection{
> >   plane
> >   quadric
> >   #declare i=i+1;
> >     #if (j<20)
> >       #declare j=j+1;
> >   #end
> >   #end
> Solution:
> Alain
> Stephan Ahonen
Now I changed my code and put 2 successive #while loops here is my new code,
but still it gives same error message, I really do not understand why?
  #declare i=0;
  #declare j=0;
  #while (i<31)
    #while (j<20)
  intersection{
  plane
  quadric
  #declare i=i+1;
  #declare j=j+1;
Date: 8 Aug 2007 07:10:00
Message: <web.46b9a4232d937f37d7b596fc0@news.povray.org>
> > > I'm new at Povray.
> > > range"
> > >   #declare i=0;
> > >   #declare j=0;
> > >   #while (i<31)
> > >   intersection{
> > >   plane
> > >   quadric
> > >   #declare i=i+1;
> > >     #if (j<20)
> > >       #declare j=j+1;
> > >   #end
> > >   #end
> > Solution:
> > Alain
> > Stephan Ahonen
>   #declare i=0;
>   #declare j=0;
>   #while (i<31)
>     #while (j<20)
>   intersection{
>   plane
>   quadric
>   #declare i=i+1;
>   #declare j=j+1;
>   #end
>   #end
I saw a mistake of mine, the rows of arrays p,q are from 0 to 29, and for qq
0 to 18, so I changed thses numbers in #while loops as 30 for planes and 19
for quadratics, but still I couldn't see any image after even 5 minutes, is
this normal in Povray?
It is written
Parsed ..... tokens
and number of tokens is changing and very big numbers,
what does this mean?
why I can not see the image?
what can I do to see my image?
Date: 8 Aug 2007 08:11:08
Message: <46b9b2dc$1@news.povray.org>
"Katherina" <nomail@nomail> wrote in message
news:web.46b9a4232d937f37d7b596fc0@news.povray.org...
>> code,
>>   #declare i=0;
>>   #declare j=0;
>>   #while (i<31)
>>     #while (j<20)
>>   intersection{
>>   plane
>>   quadric
>>   #declare i=i+1;
>>   #declare j=j+1;
>>   #end
>>   #end
> qq
> 19
> is
> It is written
> Parsed ..... tokens
You've got two nested loops, so you're in danger of intersecting all 18
quadrics 30 times, at the moment though you'll be looping forever because
the 'i' increment is in the inner loop, so once 'j' reaches 18, the inner
loop ends and 'i' stays at 18 for the rest of eternity, never reaching the
required value of 30 to break out of the outer loop.
I think what you're aiming at is probably just to intersect everything once,
so you want something more like the following code.
I haven't tested this, so it might contain typos.
Chris B.
  intersection {
    #declare i=0;
    #while (i<30)
       plane
{<p[i][0],p[i][1],p[i][2]>,p[i][0]*q[i][0]+p[i][1]*q[i][1]+p[i][2]*q[i][2]}
       #declare i=i+1;
    #declare j=0;
    #while (j<19)
      quadric
{<qq[j][2],qq[j][4],qq[j][6]>,<qq[j][7],qq[j][8],qq[j][9]>,<qq[j][1],qq[j][3],qq[j][5]>,qq[j][0]}
      #declare j=j+1;
Date: 8 Aug 2007 17:35:24
Message: <46ba371c@news.povray.org>
Katherina nous apporta ses lumieres en ce 2007/08/08 06:46:
>   #declare i=0;
>   #declare j=0;
The declaretion of the indexing MUST ALWAYS immediately precede the coresponding
#while statement.
>   #while (i<31)
>     #while (j<20)
>   intersection{
>   plane
>   quadric
>   #declare i=i+1;
You must NEVER alter any indexing variable inside any loop but it's own. Here,
you increase both in the inner loop.
>   #declare j=j+1;
>   #end
>   #end
You need to start with the intersection and put the loops inside the
intersection. Secondly, put the 2 loops one after the other, not one inside the
other.
intersection{
#declare I = 0;
#while(I < 31)
Your_planes
#declare I = I + 1;
#end// terminate the intersection of planes
#declare I = 0;// you can reuse the same variable
#while(I < 20)
Your_quadrics
#declare I = I + 1;
#end// terminate the intersection of quartics
texture{Your_texture}// unless you need each part to provide it's own texture
}// End of the intersection
'hAS ANYONE SEEN MY cAPSLOCK KEY?'
