POV-Ray : Newsgroups : povray.newusers : Normal mapping with use_color? Server Time
29 Sep 2024 04:22:16 EDT (-0400)
  Normal mapping with use_color? (Message 1 to 2 of 2)
Subject: Normal mapping with use_color?
Date: 25 Jun 2007 15:45:02
Message: <web.46801a999f23ceb57d5d9e650@news.povray.org>
Does use_color in a bump_map block make the difference between an image
being used as a bump map (normal perturbed by the gray scale value of the
texture at a point) and a normal map (the three channels r,g,b dictating
the x,y,z of the normal)?  I've looked everywhere and have found nothing.
The manual just says "the color method will be used", whatever that is.
Subject: Re: Normal mapping with use_color?
Date: 26 Jun 2007 07:57:51
Message: <4680ff3f@news.povray.org>
Probably the method is the one used for 16 bit color height fields...
where red is the MSB and green is the LSB.
