POV-Ray : Newsgroups : povray.newusers : Simple trig question Server Time
8 Apr 2026 22:58:53 EDT (-0400)
  Simple trig question (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Simple trig question
Date: 13 Jun 2007 15:15:23
Message: <4670424a@news.povray.org>
TheMightyZog <Chr### [at] hotpopcom> wrote:
> Thank you Marc, but I tried that the following
>    rotate<atan(1/2),0,0>
> should be the same as
>   rotate<30,0,0>
  It shouldn't because atan() returns radians while rotate takes degrees.
  Besides, you should really use atan2().
Date: 13 Jun 2007 15:17:28
Message: <467042c8$1@news.povray.org>
Trevor G Quayle schrieb:
> Better to use atan2(a,o).  Handles situation where o is zero.
> Also note the results of these is in radians to convert to degrees use
> degrees(A) in POV (or A*180/pi by hand).
> -tgq
You are right with regrad to POV, I explained it more the mathematical
way ...
Marc
Date: 13 Jun 2007 15:18:26
Message: <46704302@news.povray.org>
Thanks tgq, but
   rotate<(degrees(atan2(1,2))),0,0>
is not exactly the same as
  rotate<30,0,0>
 - it is a little off as I suspect it is using the arc of a radian circle
instead of straight lines
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.46703ec3f87630f4c150d4c10@news.povray.org...
> Marc Schimmler <mar### [at] webde> wrote:
> > TheMightyZog schrieb:
> > > I'm ashamed to have to ask this, but I just can not remember how to
> > > calculate an angle in degrees if I know the opposite and adjacent side
of a
> > > right-angled triangle.
> > > My only excuse is that I'm an OAP and school was just years ago and
then
> > > radians were not taught!
> > > Help!
> > > Thanks
> > > Zog
> > If it looks like this
> >         alpha
> >    h /=|
> >     /  | o
> >      a
> > alpha = atan (a/o)
> > alpha = acot (o/a)
> > alpha = asin (a/h)
> > Is this what you wanted ... POVCODE?
> > Marc
> -tgq
Date: 13 Jun 2007 15:21:35
Message: <467043bf@news.povray.org>
Thanks Warp, but
or
   rotate<(atan2(1,2)),0,0>
is not the same as
  rotate<30,0,0>
- 'tis a real puzzle!
news:4670424a@news.povray.org...
> >   rotate<30,0,0>
Date: 13 Jun 2007 16:05:01
Message: <web.46704cf6f87630f4c150d4c10@news.povray.org>
"TheMightyZog" <Chr### [at] HotPOPcom> wrote:
> Thanks tgq, but
>   rotate<30,0,0>
Of course this isn't the same.  the arctan of 1/2 is ~28.6 degrees not 30.
I.e., the tan of 30 is not 1/2, it's 0.577, you are thinking of sin(30)
which is O/H not O/A:
rotate<(degrees(asin(1/2))),0,0> = rotate<30,0,0>
-tgq
Date: 13 Jun 2007 16:15:29
Message: <46705061@news.povray.org>
  What does that even mean?
Date: 13 Jun 2007 23:58:10
Message: <4670BBFC.2030205@joplin.com>
TheMightyZog wrote:
> Thanks Warp, but
> or
> is not the same as
>   rotate<30,0,0>
the tangent of 30 degrees is NOT 1/2
   degrees(atan2(1,2))= 26.56 degrees
   degrees(atan2(sqrt(3),1))= 30 degrees
  sqrt(3)  *30 *   2
           *90   60*
               1
  sin(30)=1/2        cos(60)=1/2
  cos(30)=sqrt(3)/2  sin(60)=sqrt(3)/2
  tan(30)=1/sqrt(3)  tan(60)=sqrt(3)/1
Date: 14 Jun 2007 03:06:08
Message: <4670e8e0@news.povray.org>
Apologies for the trouble you have all been put through by my 'senior
moment'
I see the silly mistake now
And thank you Alan and Tim for your alternative suggestions
Zog
"Leroy" <lrw### [at] joplincom> wrote in message
news:467### [at] joplincom...
> TheMightyZog wrote:
> > Thanks Warp, but
> > or
> > is not the same as
> >   rotate<30,0,0>
>   sqrt(3)  *30 *   2
>            *90   60*
>                1
Date: 14 Jun 2007 03:55:02
Message: <web.4670f394f87630f4726bd13c0@news.povray.org>
> moment'
> Zog
triangle to remind me. That might be one of the reasons I use a modeler.
Date: 14 Jun 2007 04:01:31
Message: <4670f5db$1@news.povray.org>
news:web.46703502695d64ebff6e04e90@news.povray.org...
> calculate an angle in degrees if I know the opposite and adjacent side of
a
> My only excuse is that I'm an OAP and school was just years ago and then
> Help!
> Thanks
> Zog
degrees(atan2(A,B))
