POV-Ray : Newsgroups : povray.newusers : Icey Problems Server Time
29 Sep 2024 06:22:09 EDT (-0400)
  Icey Problems (Message 1 to 5 of 5)
Subject: Icey Problems
Date: 31 Jan 2007 20:55:00
Message: <web.45c146b8f302c2eeda6e9e4a0@news.povray.org>
I have this screen name on many different web site, and since I use POV-Ray,
I thought "Hey! I'll make an avater in POV-Ray!"
My ire is this: I can not find a good ice . . .
texture/interior/normal/what-have-you. I know the ice IOR, but it still
looks like glass, because it is so smooth. A texture doesn't help, nor do
normals. I can't understand exactly what to do. I was hoping someone might
know where source for good ice might be. Specifically, I'm looking for a
natural, sorta frosty, ripply looking ice, not a ice cube look. But right
now, I'm not picky. Any ice would work, and I could just fiddle with it.
P.S. I got the flame worked out. Just need ice.
Subject: Re: Icey Problems
Date: 31 Jan 2007 21:32:09
Message: <45c15129@news.povray.org>
BuRnInG_IcE nous apporta ses lumieres en ce 31-01-2007 20:52:
Natural ice often have air bubbles or other inclusions. Make them by using
several small spheres with the ior of air (1) placed inside your ice. Add some
opaque and dark bits "floating" inside. Differencing them can be very slow,
beter use an union. Another way (not tested), wrap them in a merge and diference
that from your block: may be faster for you then have only one bounding box.
Layer some whitish, partly transparent, pattern over your ice texture. Give the
white part a strong normal scaled small. granite may be a good start.
Add some dispersion.
If it's not the case now, try using an iso-surface. Carve some grooves in it by
adding some bump function, unevenly scaled.
Don't try so hard, the best things come when you least expect them to.
Date: 1 Feb 2007 00:35:00
Message: <web.45c17af9acd88537da6e9e4a0@news.povray.org>
> Alain
Thank You. Using difference helps. Right now I have 2500 clear spheres of
size 0.015 randomly placed inside a size 1 sphere. O_o it's working, but a
little slow. . .
i'll try the normal/pattern idea once i get the interior set up.
Date: 1 Feb 2007 08:20:00
Message: <web.45c1e897acd88537c150d4c10@news.povray.org>
> little slow. . .
Try manually bounding your object to see if you get some speed-up.
Sometimes difference can have bounding issues, especially with that many
objects.
-tgq
Date: 2 Feb 2007 15:53:41
Message: <45c3a4d5@news.povray.org>
BuRnInG_IcE nous apporta ses lumieres en ce 01-02-2007 00:31:
>> Alain
> little slow. . .
The slowness is due to the fact that all differenced bits have overlaping
bounding box, and that every ray have to be tested against all of them. By
merging all those small bubbles, you force them to only have 1 bounding box.
Usualy, a merge is slower than an union, but in this case, it may be faster.
Those been perty small, you may be able to get by using small white spheres in
an union, this could be faster.
   My wife's such a bad cook, the dog begs for Alka-Seltzer.
   	Rodney Dangerfield
