POV-Ray : Newsgroups : povray.newusers : trace function question Server Time
14 Mar 2026 07:05:46 EDT (-0400)
  trace function question (Message 1 to 7 of 7)
Subject: trace function question
Date: 15 Jan 2007 20:15:00
Message: <web.45ac26897946a67f75f97caf0@news.povray.org>
Hi, I'm trying to make the following script place the cylinders evenly on
the sphere, but they're showing up clustered.  Any idea why?  How can I
place them evenly on the sphere?
The original script was from:
http://www.povray.org/documentation/view/3.6.1/229/#s02_02_01_04_05_i5
Thanks.
      angle 20
      location<-5,10,10>
      look_at<0,0,0>
light_source { <0, 15, 10> color White }
background { White }
#declare MySphere = sphere { <0, 0, 0>, 1 }
object {
  MySphere
    pigment { rgb 1}
#declare R1 = seed(339);
#declare Cnt = 0;
#while (Cnt<500)
  #declare Norm = <0, 0, 0>;
  #declare Start = <rand(R1), rand(R1), rand(R1)>;
  #declare Inter = trace ( MySphere, Start, <0, 0, 0>-Start, Norm );
  #if (vlength(Norm)!=0)
    cylinder {
      Inter, Inter+Norm, .1
        pigment {color red 1}
  #declare Cnt = Cnt+1;
Subject: Re: trace function question
Date: 16 Jan 2007 01:28:22
Message: <45ac7086$1@news.povray.org>
Your Start positions are clustered, specifically in the positive
quadrant, that is why.  Also note that they are posibly < the radius of
your sphere
You might get to adequately even results most quickly by using the
"vrotate" function
ie #local Start = vrotate ( <0,0,-2>, <rand(S)*360,rand(S)*360,0> )
*remember that the triplet specifying the rotation is in degrees
Otherwise the most methodical approach would be to begin with an even
distribution of Start points around the sphere then "jitter" each
location slightly with a random factor between -1 and +1
look in the rand.inc file, there are macros there that will return a
distribution around zero and within -1 to +1.  There are also some
different types of random distributions
Date: 17 Jan 2007 01:30:01
Message: <web.45adc1ac1c5723b375f97caf0@news.povray.org>
> your sphere
> "vrotate" function
Not sure I understand it yet, but that was what I was looking for.  Thanks
for the help!
Date: 17 Jan 2007 05:41:58
Message: <45adfd76$1@news.povray.org>
"serfurj" <nomail@nomail> wrote in message
news:web.45adc1ac1c5723b375f97caf0@news.povray.org...
>> > on
This creates a random distribution of points in a space within a cube from
<0,0,0> to <1,1,1>. Some of those points will be inside a sphere of radius 1
centred at the origin and some will be outside. With the trace function you
used, the starting points outside the sphere would hit the surface of the
sphere in the +X, +Y, +Z quadrant and those inside the sphere would strike
the opposite side of the sphere (-X,-Y,-Z).
If you scale your start points up and displace them (rand(R1)*2-1), you get
a random distribution within a cube <-1,-1,-1> to <1,1,1>, which would be
closer to what you want, but would still not map to the surface of the
sphere in a uniform way, because you get more points on the sphere where you
have the edges (and particularly the corners) of the box and less towards
the centre of the boxes surface.
>> "vrotate" function
This will give you a distribution a bit like the lines of longitude and
latitude on a globe with a greater density at the poles than around the
equator. This is because the x rotation is uniform, so you get as many
points at a latitude of 80 degrees (clustered around a small circle) as you
would at the equator (a larger circle).
> for the help!
If you want a uniform distribution you probably want   #declare Start =
vrotate ( <0,0,-2>, <asind(rand(R1)*2-1),rand(R1)*360,0> );
This compensates by adjusting the distribution of the random numbers used
for the x rotation, providing more points in the middle (xRotation=0) and
less as you reach the extremes (xRotation=90 and xRotation= -90). It does
this by taking the arcsin of a random number between -1 and 1.
Chris B.
Date: 17 Jan 2007 05:50:52
Message: <45adff8c@news.povray.org>
ps. You'll need to #include "math.inc"
Date: 18 Jan 2007 16:25:00
Message: <web.45afe5111c5723b3e73422500@news.povray.org>
Thank you for the thorough explanation!  You were correct, I meant uniformly
distributed, not evenly spaced.
I understand your approach, but it seems to only apply to placing objects on
a sphere.  Is there a way to place the cylinders uniformly on the
sphere_sweep or cylinder shapes below?  Is it possible to create a random
distribution of points in a space within a sphere_sweep or cylinder?
#include "debug.inc"
#include "math.inc"
      angle 20
      location<0,0,-50>
      look_at<0,0,0>
#declare MySphere =   sphere_sweep {
      linear_spline
      4,
      <-5, -5, 0>, 1
      <-5,  5, 0>, 1
      < 5, -5, 0>, 1
      < 5,  5, 0>, 1 }
//#declare MySphere = cylinder { <-1, -3, -1>, <1, 3, 1> 0.5 }
object {
  MySphere
    pigment { rgb 1}
#declare R1 = seed(33);
#declare Cnt = 0;
#while (Cnt<500)
  #declare Start = vrotate (<0,0,-2>, <asind(rand(R1)*2-1),rand(R1)*360,0>);
  #debug concat(vstr(3,Start,",",3,3)"n")
    cylinder {
Date: 18 Jan 2007 17:11:13
Message: <45aff081$1@news.povray.org>
news:web.45afe5111c5723b3e73422500@news.povray.org...
> on
You're right it does only apply to a sphere.
Cylinders are easy, you just rotate by rand(R1)*360 around the axis of the
cylinder and translate by rand(R1)*cylinderLength along the length of the
centre line of the cylinder.
Getting uniformly random distribution on the surface of a sphere sweep is
beyond me I'm afraid. You can define a spline that corresponds to the path
followed by the sphere sweep and take a point at a random distance along it,
then you could send out traces at right angles to the line of the spline.
This would give you a uniform random distribution on the straight sections,
but you'd still get more on the inside of the bends and less on the outside
of the bends.
Chris B.
