POV-Ray : Newsgroups : povray.newusers : Background image? Server Time
29 Sep 2024 08:12:03 EDT (-0400)
  Background image? (Message 1 to 8 of 8)
Subject: Background image?
Date: 15 Jan 2007 09:10:01
Message: <web.45ab8a50eadb310ca24f7610@news.povray.org>
Hi!
I'm trying to make an animatied text overlay ontop of an image.  Looking
through the helpfile I find lots of backgroud properties to play around
with, like a solid or gradiant background color, but nothing about static
images.
Is it possible to add a static image to the background as it is with for
example 3D Studio Max, where it is very simple to do so?
TIA,
Espen
Subject: Re: Background image?
Date: 15 Jan 2007 10:58:29
Message: <45aba4a5@news.povray.org>
web.45ab8a50eadb310ca24f7610@news.povray.org...
> Hi!
Have a look at screen.inc it is in the standard includes
http://www.povray.org/documentation/view/3.6.1/495/
Marc
Date: 15 Jan 2007 17:52:09
Message: <45ac0599@news.povray.org>
Espen nous apporta ses lumieres en ce 15-01-2007 09:06:
> Hi!
> images.
> TIA,
> Espen
As your case is prety simple, this is a simple solution:
Add a large box behind your animated text. Use an image_map as the texture.
Translate the image by -0.5 to have it centered, then scale it to fit. Give it a
finish{ambient 1 diffuse 0} so that it don't interact with the light and don't
show shadows.
DONE!
Fundamentalism: If shit happens, you will go to hell, unless you are born again.
(Amen!)
Date: 15 Jan 2007 20:53:33
Message: <45ac301d$1@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:45ac0599@news.povray.org...
> DONE!
     Heh, I like your style Alain...  :o)
      ~Steve~
> Alain
> again. (Amen!)
Date: 16 Jan 2007 06:10:00
Message: <web.45acb1e5cc9c171eca24f7610@news.povray.org>
> > DONE!
>       ~Steve~
> > Alain
> > again. (Amen!)
Thanx guys!  Below is the code for reference.
, Espen
plane { < 0, 0, -1 >, -15
       pigment { image_map { tga "background.tga" } }
       finish { ambient 1 diffuse 0 }
       translate < -0.5, -0.5 > scale < 20, 20 >
Date: 16 Jan 2007 13:59:53
Message: <45ad20a9$1@news.povray.org>
Espen nous apporta ses lumieres en ce 16-01-2007 06:07:
>>> DONE!
>>       ~Steve~
>>> Alain
>>> again. (Amen!)
> , Espen
>    texture {
Before scaling, the image_map cover an area of 1 unit by 1 unit. So, if the
original image is not square, you need to scale it to the proper aspect ratio.
Your plane is as good as the box I mentioned.
As it is now, the image will be tilled over the plane. If it's incoveniant or
you don't want the tilling, you need to add the "once" keyword.
I believe that banking institutions are more dangerous to our liberties than
standing armies. Already they have raised up a monied aristocracy that has
set the government at defiance. The issuing power should be taken from the
banks and restored to the people to whom it properly belongs.
Thomas Jefferson
Date: 16 Jan 2007 14:56:42
Message: <45ad2dfa@news.povray.org>
And both are as bad if the camera is moving even a bit.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 18 Jan 2007 18:38:50
Message: <45b0050a$1@news.povray.org>
>> , Espen
>>    texture {
     // If I'm not mistaken, you put the 'once' after...  { tga
"background.tga" once}
>>        pigment { image_map { tga "background.tga" *once*} }
      ~Steve~
