POV-Ray : Newsgroups : povray.newusers : how to move an object to position <0,0,0> Server Time
17 Mar 2026 06:23:12 EDT (-0400)
  how to move an object to position <0,0,0> (Message 11 to 12 of 12)
Subject: Re: how to move an object to position <0,0,0>
Date: 8 Sep 2006 09:27:48
Message: <kurtzlepirate-669711.15274708092006@news.povray.org>
In article <web.450150251e67056d800aa0230@news.povray.org>,
 "Nostromo" <nomail@nomail> wrote:
> Thanks for your help, but it still won't rotate around the middle of thebig
> cube. Maybe someone can have a look at my code and tell me what's wrong?
> When I animate this I want the cube to rotate around it's center, but it's
> rotating around some point near one of the corners.
> Thanks a lot in advance.
well, well...
from your source whe can find that :
RMax = max_extent(Rubics) => <5.4, 5.4, 5.4>
RMin = min_extent(Rubics) => <-1, -1, -1>
translate the object with : translate -0.5*(RMax+RMin) give :
RMax = <3.2, 3.2, 3.2>
RMin = <-3.2, -3.2, -3.2>
Rubics is now perfectly center at the origin and rotations are ok. if
not, there are somes others problems :
 - your are not looking at the origin.
 - in "rotation <clock, clock*2, clock*4>" don't forget that clock varie
from 0 to 1 degrees
klp
Date: 8 Sep 2006 13:00:00
Message: <web.4501a0e91e67056d3e732b9a0@news.povray.org>
> kurtz le pirate <kur### [at] yahoofr> wrote:
> > move your "rubrics cube" by adding "translate -0.50*full_cube_size"
>   Just curious: What's the second 0 for?
when writing my own code i'd actually leave the first 0 out as well. i just
wanted to clean it up a little and went over the top maybe ;)
