POV-Ray : Newsgroups : povray.newusers : Combining thousands of smooth_triangles into an object Server Time
29 Sep 2024 12:21:15 EDT (-0400)
  Combining thousands of smooth_triangles into an object (Message 1 to 5 of 5)
Subject: Combining thousands of smooth_triangles into an object
Date: 23 May 2006 14:05:00
Message: <web.44734e3cef466b7415265f240@news.povray.org>
Hi there
I'm trying to generate a picture with two proteins (two seperate *.pov and
*.inc files) obtained from swiss pdb-viewer.
The proteinstructures are defined by thousands of smooth_triangles in the
form
smooth_triangle
{<19.880,-14.362,-31.678><-0.568,0.536,-0.625>,<19.909,-14.498,-31.821><-0.568,0.536,-0.625>,<19.999,-14.413,-31.830><-
0.568,0.536,-0.625>texture{pigment{
colour red 1.00 green 1.00 blue 1.00} finish{ RIBBON_FINISH }}}
smooth_triangle
{<19.880,-14.362,-31.678><-0.568,0.536,-0.625>,<19.999,-14.413,-31.830><-0.568,0.536,-0.625>,<20.043,-14.309,-31.780><-
smooth_triangle
{<19.880,-14.362,-31.678><-0.568,0.536,-0.625>,<20.043,-14.309,-31.780><-0.568,0.536,-0.625>,<20.025,-14.225,-31.691><-
smooth_triangle
{<19.880,-14.362,-31.678><-0.568,0.536,-0.625>,<20.025,-14.225,-31.691><-0.568,0.536,-0.625>,<19.951,-14.193,-31.597><-
..... but they are not defined as an object, so I can't use a
transform/translate command to position them. If I include both proteins in
the same pov-file they will be positioned on top of each other, which is not
pretty ;-)
I've tried enclosing each protein in a mesh with:
#declare A0_shape=mesh{
all the smooth_triangles...
but it doesn't work :-( How do I enclose each protein in it own object so I
can position them relative to each other?
Best regards,
Nigo
Subject: Re: Combining thousands of smooth_triangles into an object
Date: 23 May 2006 14:50:48
Message: <44735988@news.povray.org>
> but it doesn't work
  What do you mean it doesn't work?
Date: 23 May 2006 14:55:00
Message: <web.44735958f7c3fdecb160ffde0@news.povray.org>
One way is you can wrap a union around your include file as follows:
#declare Protein_1 = union {   #include "Bunch_O_Triangles.inc"  }
object{Protein_1  rotate <?,?,?> translate <?,?,?>  }
You might consider using your editor to do a search and replace-all for all
those texture statements, if they're all the same, and replace them with
nothing or a whitespace character... and then just apply one copy of the
texture to the union or the object.
"Nigo" <hej### [at] hotmailcom> wrote:
> Hi there
> form
> smooth_triangle
> smooth_triangle
> smooth_triangle
> smooth_triangle
> pretty ;-)
> Best regards,
> Nigo
Date: 23 May 2006 14:57:08
Message: <44735b04@news.povray.org>
"Nigo" <hej### [at] hotmailcom> wrote in message
news:web.44734e3cef466b7415265f240@news.povray.org...
> Hi there
> form
> ... snip ...
> in
> not
> pretty ;-)
> I
> Best regards,
> Nigo
Hi Nigo,
According to the documentation, this form of texture definition isn't
supported by the mesh object, which requires textures to be declared before
using them in this context.
A simple workaround is to declare the object as a union of the individual
smooth triangles whereupon it doesn't complain about the inline texture
definition. (see the following example)
Where you said "but it doesn't work". It would have been better if you'd
have listed the error message as the problem would have been quicker to
diagnose.
Chris B.
camera {location <0,0,-2> look_at 0}
light_source { <0, 50, 0> color 1}
#declare RIBBON_FINISH = finish {phong 0.5}
#declare MyShape = union {
  smooth_triangle
  smooth_triangle
object {MyMesh translate <-19.880,14.362,31.678> scale 2}
Date: 23 May 2006 15:20:00
Message: <web.44736058f7c3fdec15265f240@news.povray.org>
Thanx guys... declaring the whole inc-file as a union worked fine. Must
admit I havn't tried the other tips, but I'm looking through them and
again... thanx
/Nigo
> > Hi there
> > form
> > smooth_triangle
0>
> > smooth_triangle
0>
> > smooth_triangle
1>
> > smooth_triangle
7>
> > pretty ;-)
> > Best regards,
> > Nigo
