POV-Ray : Newsgroups : povray.newusers : How, spline-datas in an array ? Server Time
19 Nov 2025 21:09:55 EST (-0500)
  How, spline-datas in an array ? (Message 1 to 2 of 2)
Subject: How, spline-datas in an array ?
Date: 23 May 2006 01:50:01
Message: <web.4472a196f9ef9e2b5ab9a06d0@news.povray.org>
Hi folks,
in the following script, the stellar constellation
of "Orion" is drawn by 3 spline-objects.As you can
see, the while-loops are absolut identical.
Is it possible to define the spline-coordinates in
a two-dimensional array and let draw the figure by
one extended loop ?
btw.
Sorry for my english (it's not my mother language),
I hope, you can understand what I mean. And please
can you give me a litte example, how I can define
an array..if it's possible ?
Thank You for your help
// spline-model:
// stellar constellation of "Orion"
#include "textures.inc"
global_settings { assumed_gamma 1.5 }
background {Black}
light_source{<0,3,-7>, White*1.7}
  location <0, 3, -7>
  look_at <0, 2, 10>
union {
   #declare orion=spline{
   linear_spline
   1,<-1.32,3.42 ,1>,
   2,<-1.63,3.76,1>,
   3,<-2.07,4.65,1>,
   4,<-1.95,5.6,1>,
   5,<-2.07,4.65,1>,
   6,<-1.83,4.71,1>,
   7,<-1.56,5.55,1>,
   8,<-1.56,5.55,1>
   #declare X=0;
   #while (X< 8)
     sphere {<0,0,0>, 0.05
       pigment{Red}
       finish {Phong_Glossy}
       translate orion(X)
     #declare X=X+0.0005;
   linear_spline
   1,<.17,3.15,1>,
   2,<2.02, 3.15,1>,
   3,<2.015, 3.46,1>
   4,<1.79, 3.69, 1>
   5,<2.015, 3.46,1>
   6,<2.02, 3.15,1>,
   7,<1.75, 2.4,1>,
   8,<1.5, 2.3,1>
   #declare X=0;
   #while (X< 8)
       pigment{Red}
       translate orion(X)
   linear_spline
   1,<-1.3,0.5,1>,
   2,<0.45,0.65,1>,
   3,<-0.31,2.03, 1>,
   4,<.17,3.15,1>,
   5,<-0.31,3.75,1>,
   6,<-1.32,3.42 ,1>,
   7,<-0.79,1.82,1>
   8,<-1.3,0.5,1>
   #declare X=0;
   #while (X< 8)
       pigment{Red}
       translate orion(X)
// EOF
Subject: Re: How, spline-datas in an array ?
Date: 23 May 2006 16:20:57
Message: <44736ea9$1@news.povray.org>
"Meothuru" <nomail@nomail> wrote in message
news:web.4472a196f9ef9e2b5ab9a06d0@news.povray.org...
> Hi folks,
> one extended loop ?
Hi Moethuru,
It is possible, but I can't see that you'd gain much.
You can certainly readily combine the three loops by just using different
names for each of the splines so that they don't interfere with each other
in the object definitions.
You could also easily use a one dimensional array to store your splines in,
for example:
#declare Orion = array [3];
#declare  Orion[0] = spline{linear_spline ....
#declare  Orion[1] = spline{linear_spline ....
#declare  Orion[2] = spline{linear_spline ....
Otherwise, if you really want to you can assign the points to a 2D array
using something like:
#declare Orion = array [3][8] {
  {<-1.32,3.42 ,1>, ...}
  {<.17,3.15,1>, ... }
  {<-1.3,0.5,1>, ... }
Then you could build your splines dynamically within 3 loops (or 2 nested
loops), but, as I said, I can't see that you'd really gain much by going to
that extreme.
Chris B.
