![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello everybody
I want to create a globe. But I don't know how to do that. Is it difficult
to create a sphere and put the image around this sphere and then it's done?
I'm not sure because I've already downloaded a script but it doesn't work.
Maybe I'm using it wrongly. The image doesn't fit to the sphere
(http://planetpixelemporium.com/images/earthmaps/earthmap1k.jpg):
//------------- Parameters ---------//
#declare lines_color=rgbt <0,0,0,.5>; //grid map color
#declare lines_thick=.1; //earth's grid map: thickness of the lines (in
degrees*2)
#declare lines_angle=20; //earth's grid map: angle between lines (in
degree)
#declare earth_radius=6366; //earth sphere's radius
#declare groundpigment=Green //earth's pigment when no image map is chosen
#declare lines=false; //set to true if you want to have a grid map
on the earth
#declare earthbump=true; //set to true if you want to apply a bump map
to the earth
#declare earthimg=true; //set to true if you want to apply an image
map to the earth
#declare atmosphere=false; //set to true if you want the earth sphere to
have an atmosphere media around
// (not very good, needs improvement!)
#macro make_hlines(deg_interval,line_pig,line_thick_deg)
#local line_thick=line_thick_deg/180*pi;
#local i=0;
#while (i<pi/2)
[sin(i-line_thick) rgbft 1]
[sin(i-line_thick) line_pig]
[sin(i+line_thick) line_pig]
[sin(i+line_thick) rgbft 1]
#local i=i+deg_interval/180*pi;
#declare piglines_h=pigment{
gradient y
pigment_map{
make_hlines(lines_angle,lines_color,lines_thick)
scale earth_radius
#declare piglines_v=pigment{
radial
pigment_map{
[0 rgbft 1]
[0 lines_color]
[lines_thick/lines_angle*3 lines_color]
[lines_thick/lines_angle*3 rgbft 1]
frequency 360/lines_angle
#if (earthimg=true)
#declare pigmap1=
pigment{
average
pigment_map{
[1
image_map{
png "earth.png" //path to the IMAGE MAP file
map_type 1
interpolate 4
scale earth_radius
#if (earthbump=true)
#declare earthbumps=
normal{
bump_map{
tga
"EarthBumpBIG.tga" //path to the BUMP MAP file
map_type 1
bump_size 7
scale earth_radius
#declare earth=union{
sphere{0,earth_radius
texture{
#if (earthimg=true)
pigment{pigmap1}
#else
pigment{groundpigment}
normal{earthbumps}
#if (lines=true)
texture{pigment{ piglines_v}}
texture{pigment{ piglines_h}}
#if (atmosphere=true)
difference{
sphere{0,earth_radius+100}
sphere{0,earth_radius+0.01}
hollow
pigment{rgbf 1}
interior{
media{
scattering{2,<0.0005,0.0005,0.001>*.5}
intervals 5
//uncomment following for a test render
camera{
location<0,0,-40000>
look_at 0
angle 30
light_source{
<1000,100,-100000>
color White*1.4
background{rgb .05}
object{earth rotate y*-130 rotate x*-20}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Sanix" <nomail@nomail> wrote in message
news:web.4459c0de5e5702f3c2ceb9180@news.povray.org...
> Hello everybody
> done?
No it's not difficult.
camera {location <-1,1,-1> look_at <0,0.5,0> angle 50}
light_source {<30, 10, -300> color rgb 2}
sphere {<0,0.5,0>,0.5
image_map {jpeg "earthmap1k.jpg" map_type 2}
gives a cylindrical mapping (map_type 2) which I think is probably right for
this image.
For some images you may need a spherical mapping (depending on the type of
projection used for the image). For example:
camera {location <-3,1,-3> look_at <0,0,0> angle 50}
sphere {0,1
image_map {jpeg "earthmap1k.jpg" map_type 1}
map_type 1 gives a spherical mapping of an image centred at the origin.
Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
